Old 06-07-2021, 03:04 PM
hannahjazzz hannahjazzz is offline
Default Is 002 compatible with new pro tools
Had some issues with my dedicated pro tools iMac system.
Thinking of purchasing the pro tools 1 month plan for some final
Bits of recording.
I’ve got a 002 but have a new MacBook Pro with FireWire. I’d like to know if these are compatible or if I need to buy a new cheap interface for some
Mic recording. If this is the case, I’m worried the usb b to usb connection won’t be great and I won’t get the quality I need.
I’m doing some final vox recordings using a Neumann 89. Any help would be much appreciated. Thanks.
Old 06-08-2021, 08:44 AM
Default Re: Is 002 compatible with new pro tools
Hmmm, what new Mac Book Pro has firewire? The USB connection(or any connection, for that matter) has no affect on the sound quality. It may affect how much latency you hear or how many inputs can work at one time, but for recording 1 or 2 tracks at a time, even USB 1 will work. You do want a computer with enough power and speed so you can record at a low buffer setting(like 64 or 128) as any higher setting will not feel comfortable(for this same reason, avoid tracking with plugins that have high latency). My last 2 cents, get a new interface. The 002 was never noted for being "good sounding" The little Behringer UMC202HD is a great sounding little unit
Old 06-08-2021, 09:52 AM
Ben Jenssen's Avatar
What was the last MacBook Pro with FireWire?
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini 2018, six-core 3.2gHz i7, 32 gb RAM.
Focusrite Scarlett 6i6 2nd gen, Dynaudio BM6's, Command 8, SSL UC1, iPad Avid Control.
Pro Tools 2020.11.0.157, Mac OS 10.15.7.
Old 06-08-2021, 12:28 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by hannahjazzz View Post
...I’ve got a 002 but have a new MacBook Pro with FireWire. I’d like to know if these are compatible...
If your computer has FW400, then try it. Get 002/003 drivers from AVID. Get the latest version of Pro Tools that is AVID approved for your MAC/OS version. Do all recommended system optimizations. Does it work?
Desktop: PT 2020.5 / Win 10 / Intel i9-11900K / Gigabyte Z590 Vision D / 64GB / Focusrite LS56
Laptop: PT 2020.5 / Win 10 / Intel i7 / HP ProBook / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
Old 06-10-2021, 10:53 AM
And, if the MBP is actually a recent one without firewire, you COULD POSSIBLY use the 002 with adapters to Thunderbolt, but the 2 adapters would cost nearly as much as a small USB interface
Old 06-28-2021, 07:50 PM
Tubthumper Tubthumper is offline
Bumping this thread because I have a Digi 002R based system that runs on Win 7 64 bit SP1. I use it with external converters (Lavry, Lucid) along with a Motor Mix control surface via the 002R's MIDI ports.
I'm happy with the sonics and the functionality, and it's running fine, but I'm going to need to upgrade to Win 10 shortly because many plugin manufacturers are dropping support for Win 7.
My question is - how high up the Pro Tools version ladder can I go using the 002R and related driver?
For example, is anyone using the latest version of Pro Tools on a 002R using the relevant 002R driver?
Thanks
Old 06-29-2021, 06:38 AM
JoelG's Avatar
JoelG JoelG is offline
If you're sticking with Windows, you should be ok at least for Win 10. We'll have to wait and see for Win 11.
As long as the drivers for the 002R work on the OS, the PT version doesn't matter much.
Joel
Jam Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2021 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 06-29-2021, 04:49 PM
Thanks Joel, I just realised I posted in the Mac forum, apologies folks.
Is Mac 10.8 compatible with Pro Tools 10? iiLoveMusic Pro Tools 10 1 03-29-2017 01:53 PM
Pro Tools Se files compatible/exportable to other versions of Pro Tools helenvee Pro Tools SE and Essential (Win) 7 08-23-2013 08:04 AM
Pro Tools LE 6.9.2 compatible with OS X 10.4.3 ??? doctorrockter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-21-2010 11:42 AM
is pro tools 6.7 compatible with mac os 10.5? volcy Pro Tools TDM Systems (Mac) 1 05-30-2009 05:01 PM
Pro Tools 7.3.1 compatible with OS 10.4.11? Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-14-2009 10:02 AM
