Old 11-18-2002, 08:53 PM
ssd ssd is offline
Default Hardware inserts
I had my Mac PT system setup by a guy in L.A. and then he disapeared and I moved to Canada and cannot find anyone around here that knows PT.
So needless to say I am trying my best to read everything and figure it all out myself.
I am trying to connect my Antares Vocal Producer to my PT system as a hardware insert.
My System:
Mac
PT Mix/Plus
Adat 24 bridge (optical)into 2 Apogee digital I/O cards installed in a Mackie D8B board.
I have read my PT Reference Guide (page 364)about Hardware I/O inserts but nothing I do seems to work.
I don't understand how I connect the Antares to the D8B board and then set it up in the Setup> I/O. Any help would be appreciated.
Old 11-19-2002, 10:36 AM
DigiTechSupt's Avatar
Default Re: Hardware inserts
Unless the Antares unit is equipped with either ADAT Optical, RCA S/PDIF or AES/EBU I/O, this is not possible with an ADAT Bridge.
Using an interface such as the 882/20 I/O or 888|24 I/O and connecting the analog input/output of the Antares to a mathcing input/output port on the interface (i.e. input 7 and ouptut 7) is the only way to establish a hardware insert.
Brent
Avid Audio Tech Support
Support FAQ
Old 11-19-2002, 01:12 PM
Paul Turpin Paul Turpin is offline
You could set up the Antares as a send and return effect on the D8B and then route things to it from a PT Aux Send that goes the D8B and route the return back into ProTools. But thats a PITA - and it'll eat up a fair amount of the I/O you have. Seperate I/O for the insert is the only good way to do it. Digi is not just trying to sell you another box - it is the "right" way. But then again - you could end up like me with 24 channels of analog I/O + 48 channels of digital I/O and a big loan to prove it.
Paul Turpin
Champion St Sound Studios
[email protected]
Old 11-20-2002, 12:14 AM
ssd ssd is offline
Thanks for the advice (both of you). I decided to do it the right way and purchased a "like new" (oh ya) 888/24 from ebay for $1,500. Top ramen for lunch for the next 2 months, hmmmm
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
Hardware Inserts trackone Pro Tools TDM Systems (Mac) 6 01-27-2012 06:22 AM
Hardware Inserts on PT 9 Obe1 Windows 0 06-09-2011 08:19 AM
Hardware Inserts CosmicJunkie Pro Tools TDM Systems (Mac) 1 11-20-2007 03:12 AM
002 Hardware Inserts tele_player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2003 11:02 AM
