Poly BWF metadata not translating in Premiere
Hi All,
I apologize if this has question has been answered before, but I could not find a discussion pertaining to it. I was wondering if anyone has an idea how to get around Premiere truncating the metadata in a Poly BWF. I export stems in a single Poly BWF out of Pro Tools to editors but when they pull up the file the track naming is eliminated and replaced with A1, A2, A,3, etc.. This is very inconvenient and a hassle for the editor. I really don't want to send multiple stems files. I'm trying to eliminate errors caused by people hand syncing the files. The BWF's in question can be reimported into Pro tools and Media composer showing all the metadata but not premiere. Any ideas? Last edited by gtole2; 10-04-2021 at 09:11 AM. |
Re: Poly BWF metadata not translating in Premiere
PP is crap for this, but the metadata should be there, in window | metadata (*not* in bin or timeline)
Image of metadata twirldown required (might be under bwf rather than ixml on later versions): https://images.app.goo.gl/JM7CRQ6kNv4DfCs98 Link to feature request for it to be less crap: https://adobe-video.uservoice.com/fo...rt-of-audio-cl Comparison of how NLEs display track metadata (PP=worst): https://www.google.com/amp/s/www.pro...-timeline/amp/ |
Which names does PT embed and how to you enter them? Or are you talking about the regular channel names not the actual track names? (LRCLsRs etc?) Thanks!
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Yes Pro tools will embed the track names that are being bounced to a Poly BWF. for instance when bouncing to poly wave a file name
DSC_Rarefinds_30_TF_Stereo Mix will show up in the file pertaining to it when imported into Media composer. Protools, Waveagent. But Not Premiere. So in fact the data is there but Premiere does not recognize it in the bin or timeline |
Sorry I was referring to metadata in location wav files, I assumed that PT would be able to write similarly
I think those are two different things I think. But regardless PP should at least be able to list a stereo file as L/R. Sad it doesn't do that.
Using AAF and Poly BWAVs with FTP | RecRoom | Post - Surround - Video | 8 | 07-14-2014 07:55 AM |
AAX VI's with Poly-AT | RyanC | AAX Plug-ins | 0 | 06-24-2014 07:40 AM |
poly wav files and PT 9 | allegrarc | macOS | 0 | 09-05-2013 06:31 AM |
Poly pressure message on PT 8 | Noziroc | MIDI | 2 | 12-16-2009 10:47 AM |
New Poly 800 Pluggo | The Lone Roger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-23-2004 08:02 AM |
