9.0.6 no AudioBox USB Sound
I upgraded from PT 9.0.0 to 9.6.0 . My AudioBox USB quit working on playback, and record of an existing song. I tried every combination possible in the Playback Engine dialog box. I was unable to change the 256 HW Buffer Size.
Error code (-9129) came and went away after the first try. I have sound from other software sources. Regards Robert |
Re: 9.0.6 no AudioBox USB Sound
Is the Audiobox the selected audio engine? Have you tried re-installing the Audiobox driver? Did you have a backup plan(like a drive image)? Did you have a specific NEED for updating to 9.0.6?(I found 9.0.3 to be the most stable version of 9).
If the term "drive image" is strange to you, buy Acronis True Image and save a drive image the day after you get things running nicely(thank me later).
The AudioBox is displayed in the Playback Engine dialog box under Setup.
I have an Acronis true image present on a USB drive. I can go back to PT 9.0.0, if an answer can not be found here. When I installed PT 9.0.6 the installation asked me if I wanted to install Avid Audio. Should I have said NO? The fixes in .1 .2 .3 .4 .5 & .6 are as long as your arm. I think it is time to upgrade. Thanks for answering my post, Robert Thursday |
I have an Acronis true image present on a USB drive. I can go back to PT 9.0.0, if an answer can not be found here. When I installed PT 9.0.6 the installation asked me if I wanted to install Avid Audio. Should I have said NO? The fixes in .1 .2 .3 .4 .5 & .6 are as long as your arm. I think it is time to upgrade. Thanks for answering my post, Robert Thursday ( I will go to PreSonus to see if they have an update to the driver. ) |
Hmmmm. I would roll back and try 9.0.3(good on ya for drive imaging). If previous versions worked well, I think that's your best option. As for 10, you certainly could try the free 30 day trial to see how it works with the Audiobox(and the rest of your system). If it works well, the new features are great(and if it didn't, just restore from that image again). Good luck
I upgraded from 9.0.0 to 9.0.6, because the help files did not agree with the 9.0.0
version. What I saw on the screen did not resemble the online help file. Using PT 9.0.0 is like working without a manual. |
WOW, thanks guys: reloading the driver did the trick, or it was all the clicking
to select the AudioBox USB again. |
Audiobox 22vsl with PT10 | Valour Winds | Third Party Interfaces | 3 | 01-08-2014 05:35 AM |
Using audiobox usb | ascavetti94 | Third Party Interfaces | 2 | 08-05-2013 01:54 PM |
Pro Tools 10 & Presonus Audiobox USB | Elapse | Windows | 4 | 01-21-2013 05:28 PM |
PROTOOLS 10 and Audiobox USB Help | tuskaiae | Windows | 1 | 04-30-2012 04:28 PM |
PT 9.06 Audiobox USB: Nothing is right... | Tamhias | Windows | 1 | 01-08-2012 10:16 PM |
