Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-03-2022, 09:40 AM
cmbourget's Avatar
cmbourget cmbourget is offline
Default Assertion : utickunit.cpp", line 149.
Hello, I have to go back to Pro Tools and I'm happy with its qualities, but I also find its bugs...
Context: Multi-track Midi clips with real-time properties.
Action: Alt-4 (pad): Write on clips.
Message: Assertion in "d:\ protools\ release\ 2020\ r3\ protools\ app\ element_properties\ utickunit.cpp", line 149.
I tried everything: clear preferences, import tracks into new sessions, disable instrument plugins, remove my interface from Windows audio preferences (Atlas Prismsound), reinstall Pro Tools and then reinstall my driver. + Simplify my MIDI track by removing the clips already modified. Nothing to do.
Thank you for helping me. If possible!
(AMD, Win 10, PR Vanilla 2020.7) Correction: PT STUDIO 2022.6
  • Pro Tools 2023.12 Studio, Nuendo 12, Samplitude Suite Pro X7, Wavelab 11, Dorico Pro 5, Melodyne studio 5.
  • Apollo X 16 and 7.1.4 studio (Focal Solo6 be, Sub, and Focal EVO)
  • Softube Console 1. UAD systems (USB3).
  • Mac Studio M2 Ultra 2023. 2T. 128 Go. + 2X 4 T NVMe ext.
  • AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz 64 Go, full SSD
  • Roland V-Piano, Novation 88
  • Etc.
  • www.claudemarcbourget.com
Old 07-03-2022, 08:26 AM
cmbourget's Avatar
Default Re: Assertion : utickunit.cpp", line 149.
Really no one can help here? While using realtime MIDI editing on clips, every 5 minutes Pro Tools freezes with this same message! What a waste of time!
I tried everything, delete preferences, export session, re-import tracks, etc. It always comes back. It always comes back.
  • Etc.
Old 07-03-2022, 11:45 AM
BScout BScout is offline
You are on an old version. This potentially is fixed in the latest as a bug. So that leaves no one to "help you" other than to say go to the latest.
This isn't surprising -- how the software world works now.
Old 07-03-2022, 12:20 PM
Pro Tools 2022.6, Cubase 12, Samplitude Suite Pro X6 ans X7, Wavelab 11, Dorico 4, Melodyne studio 5.
Are you on 2020.7 or 2022.6?????
What is “PR Vanilla” you mean Pro Tools standard? Pro Tools Studio? Pro Tools Artist?
Old 07-03-2022, 01:43 PM
cmbourget's Avatar
Sorry, this is a mistake. I'm on the last version of Studio: 2022.6.
And the bug is there.
  • Etc.
Old 07-03-2022, 02:10 PM
The best thing with assert errors is to google them. And find out what people did in the past to solve or if the bug was fixed etc... e.g. Google
Assert "utickunit.cpp"
which in this case turns up nothing except your error. So no go there, and maybe it's a new bug introduced from all the changes/other bug fixes done to MIDI recently (which means you might try this on 2021.12 or 2022.4 to see.. even if not to run on that might help Avid engineering fix the issue).
If you tried before importing the MIDI into a new session, probably the only other thing I'd try is starting with a completely empty session and not importing anything and try to replace it there.
But even if a previously unknown ASSERT the nice thing is it should be relatively easy for Avid engineering to make progress on. They might want/need other log information, or a copy of the session from you, so at this point file a support case and get them the info needed. Hopefully support won't waste your time too much going over what troubleshooting you've done already. I'd really get that report in now while Avid seems to be focusing so much in improvements in MIDI.
Old 07-03-2022, 02:50 PM
cmbourget's Avatar
Okay, I'll do that. Note that this is a problem I've had with earlier versions. But this is worse than ever. I can barely work (as far as I work with these functions). Anyway, I'm making a ticket to the technical support.
p.s. Maybe you can see this yourself: take a complex midi file. Copy it to 3 tracks (or more). Change the real time properties of the track. Then go and randomly change the realtime properties of several clips on the 3 tracks. Try to compute, as if you were hours editing to find what you want. At some point, Pro Tools can't take it anymore. And if you try to simplify at that point, it doesn't work anymore. There's something in the file that's corrupted forever.
  • Etc.
Old 07-03-2022, 03:15 PM
It's unusual you've had this for a while on other versions and there are no posts from other users findable on Google. Do all the past ASSERT occurrences all name the exact same file "utuickunit.cpp"?
Don't worry about the file path or exact line number. This is the C++ source code file that a developer has put an ASSERT macro in to check something, and it's failing that ASSERT test and deliberately crashing Pro Tools with this error.
Others not reporting it with that error message doesn't mean folks are not seeing it. I just suspect here are very few user making much use of real-time MIDI effects. But maybe it's something in your environment or workflow tripping stuff up. All good reasons to start a support case.
Old 07-03-2022, 03:40 PM
cmbourget's Avatar
Naturally, the first thing I did was to Google. Nothing. I'm alone in the world with this assertion. But as you say, it may be more general if we stick to the essential message.
I make extensive and complex use of the real-time options in Pro Tools. Pro Tools doesn't have a good reputation at MIDI, but that's not fair. It offers unique, intelligent and very well done features. The only problem is when it crashes. It seems to me that since I bought an AMD computer, it's worse. We'll see.
Thanks for your support.
Follow-up: The technical support is informed, with all the usual elements. I am surprised at the speed of the response. I am told I will hear back on Thursday (the technical meeting is Wednesday).
  • Etc.
Could not create a new document because Assertion in "/Volumes/Dev..." line 1813 theholdingcoat macOS 24 01-15-2023 01:31 PM
assertion in "..\Mdie_TrackPlayer.cpp", line 469 / access violation/ DAE error -9400 thibault 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-22-2013 05:08 PM
FIXED: Startup issue: "Could not complete request because Assertion line 1424" wheret Windows 2 07-11-2012 05:43 PM
Problems creating fades, "assertion in...., line 865 ()" BookSix Pro Tools TDM Systems (Mac) 1 12-17-2009 01:30 PM
An assertion occured in "Sys_typed InStream",Line 68 abraxas Pro Tools TDM Systems (Mac) 0 09-07-2002 01:16 AM
