Old 05-27-2021, 04:55 AM
JanuS JanuS is offline
Default No SRC in 2021.3.1
Hi there, since I've updated to 2021.3.1, the SRC function doesn't work.
I've only tried the 24->25 SRC. But I've tried it both ways: importing with 50.000 samples to 48.000 samples, en vice versa, exporting from a 24fps session to a 24fps file.
It does take it's time to process, but nothing (the 4% shorten) happens...
A colleague of mine has the same issue on 2021.3.0
We both run on MacOS 10.14.6 Mojave
Old 05-27-2021, 07:37 AM
gives's Avatar
gives gives is offline
Default Re: No SRC in 2021.3.1
What interface? Operating system Details please-:)
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 05-27-2021, 07:44 AM
gives's Avatar
Maybe this will help. Watch it in the middle for sure.
https://www.youtube.com/watch?v=Xnz62kvLKvU
Sample Rate Conversion in Pro Tools
Old 05-27-2021, 09:22 AM
Hi Gregory,
Interface is MTRX Studio. But that's not applicable here I think..
In that video link you've added it's about SRC via session sample rate change, and import session data SRC.
I'm only talking about Audio Import with SRC, and File Export As SRC. Because that's what I use for years now ;-)
Old 05-27-2021, 10:15 AM
Sonopolis Sonopolis is offline
There was a confirmed bug (PT-269035) affecting SRC on audio import in 2020.12. From the release notes of 2021.3 this should have been fixed. Maybe the messed something else up now.
Does the audio import window show the correct sampling rate in the conversion section after choosing the conversion preset from the pull-down menu?
Old 05-28-2021, 04:38 AM
Hi, yes, the correct conversion presets come up.
So, it's not only audio import src that doesn't do anything, also "file export as" doesn't sample rate convert..
Maybe it wasn't fixed after all..?
Old 05-28-2021, 05:15 AM
I can't try 'cause I haven't updated to this dreadful version but if you're sure you should get a support ticket and report this as a bug.
Old 05-28-2021, 06:38 PM
gives's Avatar
I'd reach out to support. Sorry I misunderstood or mis answered your post. I was in the middle of 3 projects and just glanced at this when I was looking for something else.
I went to 2021.3.1 a while ago and am super happy with it except for the QT movie bounce bug, which I am working with Avid on at the moment also.
I'll see if I can look at this over the weekend if you want and see what I can find out from the hire ups at Avid. G
Old 05-29-2021, 07:30 AM
gives's Avatar
Is this it? Under Bug Fixes in 2021.3.0 so I would assume it's good in 2021.3.1
Import Pro Tools 2021.3 Release Notes
https://avid.secure.force.com/pkb/ar...611&popup=true
Selecting an SRC pull value in the Import Audio Window will once again use the correct value for sample rate conversion (PT-269035)
Old 06-01-2021, 02:38 PM
bobbyh bobbyh is offline
Hi All,
Been having the same issue, I've been trying to do a pull down (from 24 to 23.98) all morning. Running 2021.3.1, also tried it on another system with 2021.3.0 still nothing. I was finally able to successfully do it in 2020.12.
^^ regardless of the description of this bug fix, whenever you apply a sample rate conversion in the import audio window, no conversion actually applies it looks like it just reprocesses the audio? Hopefully they fix this soon.
Monitors in 2021 rmccam Post - Surround - Video 30 08-09-2021 07:27 AM
2021.3.1 innesireinar Pro Tools 80 04-22-2021 01:31 PM
Come on! 2021 already. Just issue what’s right. DetroitT Pro Tools 2020 0 03-05-2021 05:35 PM
