Old 01-25-2022, 12:12 PM
Protoolstuff Protoolstuff is offline
Default Bounce mix MP3 has no sound
when i bounce mix to an mp3, the mp3 file has no sound. output is 1&2. Not highlighting, I want everything.
Old 01-25-2022, 04:58 PM
Sardi Sardi is offline
Default Bounce mix MP# has no sound
What happens when you bounce to another format?
And what do you mean by ‘not highlighting, I want everything’?
Old 01-26-2022, 05:25 AM
Default Re: Bounce mix MP# has no sound
I tried WAV. Same result.
I did not highlight any tracks when I bounced.
I tried highlighting tracks and still no sound.
Old 01-26-2022, 06:12 AM
Bookerv12 Bookerv12 is offline
You are misunderstanding bounce.
You do not need to highlight tracks when you bounce....you do however need to highlight/select a time amount to bounce.
You can select up in the time ruler or select the time amount you want to bounce in a track.
When you bounce, you have to 1.make a time selection. 2.choose a format. 3. tell it where the bounce will go. (Desktop, back to the session, another folder, ???)
you're leaving out a lot of info
bookerv12
Old 01-26-2022, 08:14 AM
Ben Jenssen's Avatar
Also, one needs to select the source of the bounce, usually Output 1-2.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini M1, 16gb RAM. MacOS 11.6.3 Big Sur. Pro Tools 2020.12.1.191.
Olasonic DAC, Dynaudio BM6p, Artist Mix, SSL UC1, Control on iPad.
Old 01-26-2022, 12:39 PM
Nistov Nistov is offline
Any chance you are set up with a bus structure that feeds a master recording track, and that this track is switched to Input for you to listen to your mix «live» via this recording track? In that case you need to switch the bounce source to the bus that feeds the recording track.
Old 01-26-2022, 03:01 PM
Yep. All this sounds like the wrong bounce source is selected. Triple check your routing and what you’re actually bouncing in the dialog window.
Also, as mentioned above, you need to highlight an appropriate length of time. If you want the whole song, then highlight from the start to the end.
Old 01-27-2022, 12:15 PM
Default Re: Bounce mix MP3 has no sound
Thank you all for the replies to my post. I have tried everything that has been suggested. Nothing gets me sound. I know I am missing something.
I have selected a timeline
I set output 1-2 (all tracks have same)
I am selecting MP3
I set sample rate to 44.1
I set file format to interleaved
I set it to write to file
I set encoding speed to slowest
I set tag type to 103 v1.1
I set bit rate to 320
I am running version 2020.12.0 of ProTools
Old 01-27-2022, 12:21 PM
I am selecting MP3
And here, just below mp3 selection, you select the output 1-2, right?
Old 01-28-2022, 09:05 AM
Yes output 1-2 are selected.
2019.6 Bug? Quicktime bounce w/o sound when online bounce peterle Pro Tools 2019 6 09-07-2019 12:27 AM
No sound after bounce Rebecca0630 Windows 10 01-14-2013 09:52 AM
sound quality/ bounce pt noob Pro Tools M-Powered (Win) 1 02-04-2006 01:11 AM
Different sound the second bounce stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-15-2005 02:24 PM
Sound changes after bounce. BxThree1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2005 07:45 AM
