Old 04-28-2025, 10:07 AM
Jord'n Jord'n is offline
Default Playlist/comping workflow confusion
I'm practicing using playlists to comp in my first vocalist recording session and am confused by the contradictions in the information I find. I see that people will record the initial take, then manually create each new playlist. These playlists will be automatically numbered when the naming window comes up. But I also noticed, while practicing, that if I simply record over a take, Pro Tools automatically creates a new playlist with a new number. I can see recording the initial take and, to preserve separately, creating a new playlist with a new name that would indicate these are playlists based on the main take, but after that, I don't see the need to constantly take the extra step to manually create new playlists from the same take unless, for some reason, I want to rename a whole new group of playlists. Does this make sense?
I'm curious what efficient workflows users here employ?
Looking forward to the feedback!
Old 04-28-2025, 10:31 AM
Wireline Wireline is offline
Default Re: Playlist/comping workflow confusion
Your method matches mine, in that I don't rely on auto anything. When I want another take, I click on new Playlist and follow the naming scheme. Often times I'll change the name to reflect the date, arrangement, whatever.
Come comp time, I've never had nary a hiccup, but will add I've never used Playlist for anything other than actual audio, be it single tracks or groups/busses
Ken Morgan
Midland, TX
A Musical Nobody Since 1972
2017 Intel Mac Mini, 32G, PT 2024.6.0 Studio, Presonus Quantum 2626 or 1824C (whichever works) and a bunch of stuff via ADAT
Old 04-29-2025, 09:32 AM
chompers2022 chompers2022 is offline
[QUOTE=that if I simply record over a take, Pro Tools automatically creates a new playlist with a new number. [/QUOTE]
That is not correct. Pro tools does not automatically create a new playlist. Im not sure what you meant by that.
Unless you are "loop recording". there is an option for that.
Playlist comping in 2018.12 reflexson Pro Tools 2018 10 02-22-2019 05:37 PM
Confused about comping/ playlist Sam C macOS 3 03-07-2013 07:21 AM
Best workflow when comping a track from playlists? LSW Tips & Tricks 11 04-23-2009 07:26 AM
Comping Playlist feature in PTLE 8 nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-30-2008 05:49 AM
comping workflow drenched 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-17-2001 07:01 PM
