#31
I get irrationally angry every time I accidentally bump the stupid master window that everything else has to live inside simply because I can't just maximize it and have it fill both monitors completely.
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
#32
Humm not really clear on what your are describing ? Cant you resize both to just shy of full screen ?
System : Studio - Avid Carbon interface , PT Studio 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.4 Mobile - 2021 14 " MBP M1 Pro PT Studio 2024.10 --Sequoia 15.4.1 Enjoy the Journey.... Kev... |
#33
It is indeed not unusable. This topic is about the poor user experience. I hope it can attract official attention. Thank you for heating up the topic and attracting more people's attention.
#34
![]() Quote:
Search this forum for Borderless Pro tools for Windows and thank me later. |
#35
The title in this post describes an underlying element of the way Pro Tools windows are managed. Nowhere else in the OS is this Windows Vista element shown, which initially led me to believe that Pro Tools itself was specifically coded to have the vista style borders. So it stands to reason that, the way you get rid of the Vista borders is to just update the UI. However, every subsequent pro tools update then on that changed the UI, including the addition of a dark theme overhaul, it did not change the vista borders at all. Upon further reading, I believe this is actually the result of how windows are managed within Pro Tools. Unlike most modern creative apps, Pro Tools does not offer a meaningful degree of multi monitor support at all. Instead, it relies on a parent / child window style of management that forces this legacy element onto the Pro Tools experience. This is only restrictive and counterintuitive for production and efficiency, seeing as having multiple monitors is not something that pro tools has the ability to take advantage of. It seems that the way to solve this is to redesign the pro tools windows to have multi monitor support.
In addition to the "Vista style" window borders, file dialog boxes (open, save as, etc.) are also outdated in Pro Tools on Windows. If you have Windows set to dark mode for File Explorer, you'll notice that Pro Tools file dialogs ignore that setting. Actually, Pro Tools is using "Vista/XP" era file dialogs as well which pre-date the dark mode option (select File-Open in Pro Tools, and File-Open in Windows Notepad to see the difference). My assumption is that they're using older Windows libraries to instantiate things like file dialogs and window borders. While it still "works" for the time being, you'd imagine that at some point Microsoft might deprecate those libraries, so Avid should address it. In addition to being aesthetically unpleasing, it's just seems a bit lazy (Windows 8/10 have been out for several years) or potentially indicative of some other deeper issue with being able to update that code within the application. |
#36
Thank you for your reply. There is no official news. It is actually unavailable now.
#37
are you on Classic mode .That is the mode i like the best?
#38
No matter in any mode, it has a blue border similar to Windows 7
#39
Hi folks,
I developed an Autohotkey script to remove the borders. https://github.com/strain08/Pro-Tools-Fullscreen-App Until Avid does a proper UI revamp, I think this is the cleanest method to get rid of borders. If you encounter problems using the script please use the Github Issues page here: https://github.com/strain08/Pro-Tool...een-App/issues |
#40
Interesting thread. The single biggest issue that keeps me on a mac over windows is the lousy master window that makes full screen and multimonitors so inferior to a mac. Even on my Macbook, I can go full screen with both of the edit and mix windows and then swipe back and forth. This is an efficiency saver vs windows that helps ms work faster. There are other pros and cons on both platforms. I think if this UI of the windows was equal then using a PC would win out. But the way it is, the mac is just better.
zen go interface and pro tools | madmuslim | Third Party Interfaces | 0 | 02-27-2023 03:03 AM |
Interface for Pro Tools 12 | minamina | Pro Tools 12 | 2 | 03-07-2018 05:03 AM |
The Best Interface for Pro Tools 10 HD | montmoney1000 | Pro Tools 10 | 13 | 07-03-2015 10:14 AM |
how use pro tools without interface | pinnacle | Pro Tools 10 | 12 | 10-09-2013 05:49 PM |
Best interface for pro tools hd | Raoul23 | Pro Tools TDM Systems (Win) | 2 | 09-26-2010 05:08 PM |
