Old 07-30-2013, 08:50 PM
SearingSounds SearingSounds is offline
Default Minimize Additional Latency noise
Hello,
I opened up Pro Tools 11 today to try out the low latency mode that Avid added. I checked the "ignore errors" button and then the "minimize additional i/o latency" button. When I record enabled an audio track I get a static noise. When I uncheck it, it goes away.
In the manual it said there might be some problems for slower computers but Im on a 3.4 GHz Core i7 iMac. Does Avid consider this a slow computer? Can anyone help me with this? Thanks
Johnny
Old 07-30-2013, 08:58 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Minimize Additional Latency noise
So I assume a lot -
Ur using two drives ?
Ur using at minimum of 7200 drives (the bigger the cache the better)
U have the buffer set at a value besides 32smpls?
Daniel
Old 07-30-2013, 09:02 PM
Originally Posted by YYR123 View Post
So I assume a lot -
Buffer set to 64
Recording audio to a Glyph Portagig (7200)
Old 07-30-2013, 09:07 PM
So I assume a lot -
When I choose the 32 buffer size without "additional latency" checked I get the same noise.
YYR123's Avatar
What about 128?
Daniel
Old 07-30-2013, 09:12 PM
What about 128?
Anything above 32 there is no noise. Check the "additional latency" box and I get noise on all buffer sizes. The noise is a whining static noise. Thanks
Old 07-30-2013, 09:15 PM
YYR123's Avatar
FireWire device huh
Daniel
Old 07-30-2013, 09:18 PM
FireWire device huh
my external drives....yes...FireWire 800
Old 07-30-2013, 09:19 PM
YYR123's Avatar
No your audio interface
Daniel
Old 07-30-2013, 09:21 PM
That is a Duet 2 and it is connected via USB. Do you think the Duet could be the problem?
PT 9 - "Minimize additional I/O latency" PROBLEM elmodagansta Windows 2 04-27-2013 06:11 AM
Minimize Additional I/O latency william.bond55 Pro Tools 10 0 03-16-2012 08:44 AM
Whats the best way to minimize midi latency weezerboy MIDI 3 08-04-2008 09:44 AM
How to minimize latency ram1500 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-02-2007 03:13 PM
how best to minimize latency? vyatka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-11-2000 07:48 PM
