Old 02-11-2016, 07:44 AM
gdgross's Avatar
gdgross gdgross is offline
Default Click in 6/8
Got a track in 6/8, temp is 53.3333bpm (don't ask - it was started as a 6/4 session, with a quarter note = 160...).
However, I can't figure out how to get the click to sound on all six beats of the measure. Currently the downbeat click sounds and the secondary click sounds on 1, 2 and 3, but is silent for 4, 5 and 6.
Any ideas? Thanks again in advance!
Screen Shot 2016-02-11 at 7.42.44 AM by gdgross2001, on Flickr
Screen Shot 2016-02-11 at 7.42.57 AM by gdgross2001, on Flickr
Old 02-11-2016, 08:23 AM
john1192 john1192 is offline
Default Re: Click in 6/8
click on the little Plus Sign next to Meter in your Edit Window Timeline .. change that Click to 1/8 note .. should do what you want ...
this is different from the Click in the Bar at the Top of PT Edit Window .. that remains at 1/4 note
cheers john
File Type: jpg Screen Shot 2016-02-11 at 8.22.01 AM.jpg (55.4 KB, 0 views)
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-11-2016, 08:59 AM
joachim's Avatar
joachim joachim is offline
And maybe click to highlight "Follow Meter" in Click II ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 02-11-2016, 09:31 AM
yes, this needs to be on .. and you have to change that Click Ref in that window .. it is odd to me the way we have to do this ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-11-2016, 05:29 PM
Courtlaw Courtlaw is offline
I'm working a piece that's in 9/8 which is essentially 3 1/8 notes to beat so I set the meter to 1/4 note plus ". "time and it solved everything
- Steve
2013 iMac Late model i7 3.5 Ghz quad-core, 24 gigs ram, OSX 10.12.3
PC slave, i7 6700 4.0 Ghz quad-core, 64 gigs ram, SSD drives running VE Pro 7
Multiple external thunderbolt SSD hard drives
UAD Apollo X8, Twin Duo & Quad Satellite Thunderbolt
Townsend Sphere L22 w/ Putnam Mic Collection
LUNA (I have Pro Tools 2020 as well)
Old 02-11-2016, 07:54 PM
gdgross's Avatar
Thanks guys! Easy fix
Old 02-12-2016, 07:18 AM
steve, so you set to Dotted 1/4 note ... did you do this in the Main Edit Window Click or in the Meter Click Window ??
gdgross, Good to Hear you are good .. and we are all learning a couple new ways to do things .. i know i am ..
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 05-26-2021, 10:57 PM
EL CHAKTOR EL CHAKTOR is offline
I had the same problem and i got the solution. First select the region where you have the different meter and then press ALT+1 (Only numeric pad) Time Operations window will be open and then you can change the click to 8ths or 16ths or wherever you need, press apply and Voilá.
Avid can you please sort out the click track & Click 2 plugin protoolsuserman Pro Tools 11 14 11-14-2013 08:11 AM
Getting the click track to click at 16th notes... broken81 Tips & Tricks 1 06-27-2008 07:06 PM
Click Track - How to "UN" accent the click plugin pepperbox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-02-2006 06:37 AM
Mbox needs TWO click plugins for the click to work drguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2004 12:01 PM
Power Harness, click click click director 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-14-2004 09:50 PM
