Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 11-30-2022, 09:47 AM
DigitalDragon DigitalDragon is offline
Default muted when all mute are on.
headline error ^^^
correct headline
muted when all mute option turned off hello yall
its been happening where i start a session and no playback even though no mute buttons are on. i check i/o everything fine and sound control panel its fine. other tracks play fine. what is it that im not seeing? please help thanks.
Old 11-30-2022, 11:52 AM
Default Re: muted when all mute are on.
Couple of possible things:
1-wrong audio engine under Hardware
2-wrong output path
3-something in solo mode, even a hidden track
Old 11-30-2022, 06:30 PM
hi dave and people.
i tried the solo mode that wasnt the problem, i default i/o and now i put a master fader no sound from there. i added plug in space and saw meter movement on everything but no sound.i wish to solve this. any help. thank you.
Old 11-30-2022, 07:43 PM
hidden track?
Old 12-03-2022, 04:35 AM
only thing that works is moving clips to new audio track plays right away. i dont know if its a bug or what.
Old 12-03-2022, 10:33 AM
The Weed's Avatar
The Weed The Weed is offline
Is the Mute Button greyed out? Ctrl+Click it to see if it's Safed.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-03-2022, 01:02 PM
i dont understand you? safed? and control? click? sorry dont understand
Old 12-03-2022, 03:40 PM
Tweakhead Tweakhead is offline
if you post a high-resolution screenshot of your Mix, Edit, & IO Windows, I bet someone here will immediately spot the problem.
Old 12-03-2022, 09:42 PM
heres the screenshots. hopefully can fix
Sent
Windows 11 pro i5
Pro tools Studio
16gb ram 500 memory
ssl 2+
Old 12-03-2022, 11:11 PM
i meant its muted when all mutes are off. sorry
Some audio is not muted but acts muted LizziF Pro Tools 12 8 11-01-2021 09:35 PM
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
Speaker mute,unmute, record track mute,unmute for ADR garret Post - Surround - Video 7 09-04-2015 01:03 PM
BUG> Send doesnt mute when track is muted peterle Pro Tools 10 7 07-31-2014 08:24 AM
Mute Region or Mute Automation Jeremy Mix3000 Pro Tools TDM Systems (Mac) 9 01-22-2007 07:53 PM
