Renaming Disc Files?
It seems once you’ve edited a region, the option to rename the disc file in the rename window is no longer available. Therefore, if you rename a region something simple like “final vocal”, it will still show up in your audio folder as something like “vocal-3-22-00”. Although you can use the “Show Full Pathnames” setting in the region window to note the actual root file name, this makes file management and importing very difficult. Any suggestions?
------------------ bassmac |
Re: Renaming Disc Files?
Solved it! After doing all of your edits to the track. “Consolidate Selection” gives you a new disc file you can rename and then junk the others.
Renaming Files by TC-Stamp | Frank Kruse | Post - Surround - Video | 4 | 05-03-2009 04:19 AM |
Autosuite without renaming the files?..Help | postman56 | Pro Tools TDM Systems (Mac) | 0 | 12-11-2008 09:47 AM |
Renaming Files | n3xus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-25-2005 01:12 AM |
Lost files and renaming files | GoneIndie | Pro Tools TDM Systems (Mac) | 2 | 01-13-2005 07:08 PM |
renaming regions/files | Emo King | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-17-2002 12:59 AM |
