Problem With Last Track
Hi All,
I have an annoying problem with PT LE 5.1. When I drag regions down to the bottom track they seem to "disappear". They just won't move to that bottom track properly. It happens when I am in large sessions nearing the 24 tack point. Sometimes hiding some other tracks helps. Sometimes changing positions of the bottom track works as a workaround. But has anyone else seen this sort of behaviour? What's up?
Eli Krantzberg Nightshift orchestra Almat Productions |
Re: Problem With Last Track
I have tried, but cannot reproduce this behavior. Does this happen with all sessions?
If not, perhaps you should try to import the tracks into a new session (File>Import Tracks) and see if the behavior persists. If so, is there any specific sequence of steps that might allow us to replicate this issue? Brent |
Hi Brent,
Thanks for your response. No, it doesn't seem to happen all the time. Would the fact that the lowermost track is part of a group be a possible cause? I'm not certain if that is consistently the case when it happens. I'll check more carefully what the exact circumstances are next time. Importing tracks is one possible workaround, but there are often markers involved in the session that I don't want to lose. I have been able to work around it when it has happened by juggling the track positions and hide/show status.
ADC and AUX TRACK - BIG PROBLEM | Siddhant Bhatia | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-15-2011 08:33 AM |
Problem bussing audio from one track to another audio track | harryk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-04-2010 12:15 PM |
Track 1 & 3 problem | ntime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 08-02-2009 04:56 AM |
Problem Converting Instrument Track to Audio Track | Gorbies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-02-2009 09:11 PM |
can't pan track problem ? | jackp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-22-2008 09:34 PM |
