Old 01-25-2011, 06:13 AM
jcolagross jcolagross is offline
Default Digital Spike source?
I go into PT 8.04 through an Apogee AD16x, with PT clock set to ADAT, so I am using the AD16's Big Ben clock, then I come out into a Rosetta using S/PDIF. I was recording last night and getting periodic digital spikes (pops). What is most likely the problem?
Old 01-25-2011, 06:16 AM
miketeachesclass miketeachesclass is offline
Default Re: Digital Spike source?
Post a sandra report (you can find more information in the "Help us Help You" thread), and more people will likely chime in.
Also, search the board for "clicks and pops". This is a recurring issue. You might find some suggestions there.
Old 01-25-2011, 06:23 AM
Thank you.
Old 01-25-2011, 09:59 AM
If you change the digital source from optical(ADAT) to SPDIF, you need to also change the clock source. In any case, all devices must work off a single master clock. Which interface you have will determine how that gets done.
Old 01-25-2011, 10:22 AM
I assume the Big Ben in the Apogee AD16X is the way to go. So, in ProTools I select clock source as "ADAT", since I am using a 002R, right? S/pdif is being or the D to A (Apogee Rosetta 200). I think ADAT is the only way for me to get the 8 channels in digitally from the AD16X. Thanks for your help Albee. You were the one who helped the most last year when I was building my computer. (You and Guitardom)
Old 01-25-2011, 06:10 PM
You are most welcome(and guitardom is the best)
Old 01-26-2011, 07:00 AM
My signal flow now is pres to Apogee AD16X then ADAT lightpipe over to DIGI002R, then out to Apogee Rosetta by way of S/PDIF. The session is 44.1/24bit. (I made sure the DIGI, AD16X and Rosetta all match this.)In ProTools, under "setup" and "hardware", I set clock source to "ADAT". Is there any step I am missing? Anywhere else I need to choose the clock? I tried swapping the clock from internal, to ADAT, to S/PDIF and I get the digital artifacts (small digital pops, not big spikes, just audible enough to ruin the recording. I'll work on the Sandra. As a side note, possibly related, when I bring up the Virtual instrument "Mini Grand", when I hold a chord, it cuts off after a second or two. It's never done that before. I don't know if these are related problems or not. Thank you
Old 01-26-2011, 08:05 AM
Given this signal flow, I think the Rosetta needs to be set to clock to the incoming SPDIF(from the 002r). I was thinking you had IN-coming audio on both optical and SPDIF. As I re-read this, I bet you were not aware of the 8.0.4 bug where Pro Tools reverts to internal clock on every system boot That's right, since then(and with PT9) you need to reset the clock source after every boot.
Digital Noise Issues - Clock Source Issues? Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2010 01:55 PM
Source ZIP- a new nifty utility from those Source Connect People MIKEROPHONICS Pro Tools TDM Systems (Mac) 0 01-13-2010 09:05 AM
digital spike while bouncing down doylemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-09-2003 05:11 PM
Digital Clock Source kcarter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-09-2001 10:58 PM
digital noise when locking to external source gadget Pro Tools TDM Systems (Mac) 0 08-25-2000 08:03 AM
