Old 11-23-2007, 03:16 AM
Rob S Rob S is offline
Default Can you retreive saved plug in settings via automation?
Hello all,
I am running a complex mix for a feature film and I have setup several EQ and compression settings for plugins. All are saved and named. What I want to know is, is it possible to recall a 'preset' for a plugin using automation?
I am convinced there must be a way but I am not having much luck.
Any help would be greatly appreciated.
Cheers,
Rob
Old 11-23-2007, 03:46 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Can you retreive saved plug in settings via automation?
Hello all,
Cheers,
Rob
No, you can't recall presets using automation!
Best you can do is have 2-3 plugs on a track with different presets and mute them on and off with automation as needed.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-23-2007, 04:08 AM
Drew Mazurek's Avatar
Sure you can. Not directly by recalling the presets, but by using Snapshot Automation. Instructions start on page 821 of the 7.4 Reference Guide. Check it out.
www.drewmazurek.com
Old 11-23-2007, 06:36 AM
Thanks Chaps!
Plug in settings saved as "clippings" like DP filobus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-20-2010 01:43 AM
Plug in saved settings? Jono_G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-25-2010 06:13 PM
Automation of Plug-in Settings dsetaro Tips & Tricks 2 12-24-2007 07:35 AM
Automation on SAVED plug in settings jkatcher Post - Surround - Video 2 06-26-2006 01:42 AM
are plug-in settings....... saved?? gitarzan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-12-2003 11:27 AM
