Have you seen this Clip Gain bug?
With every PT HD update I check to see if this bug is fixed as I've been dealing with it for years. Here's the scenario (I work in Post, so I run into this after importing OMFs or AAFs):
If various clips have clip-gain applied, I might want to see the full, nominal, waveform and "zero" everything out, so from the Edit Menu I choose Automation > Convert Clip Gain to Volume Automation. (Coalesce has the same bug). For clips that had Clip Gain at LOWER than 0: If you show volume automation and zoom all the way in on the end of the clip, you see the new volume doesn't continue to the end of the clip -- there's a 1 frame ramp to 0 volume, which often causes a loud tick or pop. Pics attached. |
Re: Have you seen this Clip Gain bug?
I see a 1 SAMPLE ramp, Win 7 , PT 11.3.1.
And funnily, with the track set to Ticks prior coalescing, there is no ramp.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Sorry - yes, it's one SAMPLE, not a frame.
Thanks for checking on Windows. Interesting info about the Ticks setting. I can confirm the same behavior in Yosemite. |
Adjusting Clip Gain On More Than One Clip | Blank Frank | macOS | 17 | 05-15-2015 06:34 PM |
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
Export Clip With Clip Gain | BobbyDazzler | Pro Tools 10 | 0 | 03-03-2013 03:06 PM |
Clip gain on clip groups: bug or feature? | idris | Post - Surround - Video | 6 | 01-02-2013 10:48 PM |
Clip gain??? | calle.vs | Post - Surround - Video | 10 | 02-15-2009 03:02 PM |
