Old 12-30-2001, 01:09 PM
CCash CCash is offline
Default Re: 001 won\'t chase time code!!
I have no problem chasing MTC, but I'm using an Opcode interface into a GeeThree serial port on the Mac. I had to configure OMS and put PT online and it works fine. Give some more details on your setup.
Old 12-30-2001, 07:14 PM
jason levy jason levy is offline
Hmmm. mine does.
I think all the magic is in the "session setup window" did you play around in there? When you input MTC and open the "session setup window" and look at "current time" do you see running time code?
Did you read the following article? http://www.digidesign.com/support/faq/ptletc. html
Did you click on the "little clock" icon in on the transport window to tell PTLE to look for the MTC and slave to it?
Is your midi port showing up in OMS?
Not sure what else to suggest. Good luck!
jason
Old 12-31-2001, 12:33 AM
chris vrenna chris vrenna is offline
Default 001 won\'t chase time code!!
hi all,
I have an 001 on a G4, and I need it to chase midi timecode generated from my USD off my other Mix rig. It just won't see it. Any suggestions??
Thanks!
Moving Start time and time code with it... KungFuLio Pro Tools TDM Systems (Mac) 15 08-05-2009 08:42 AM
"Waiting Sync Point" trying to chase time code? Matthew Steel Pro Tools TDM Systems (Mac) 4 12-05-2007 01:45 PM
QT time code won't match to PT time code in PT LE jah-d Post - Surround - Video 4 07-28-2006 10:44 PM
couldn't lock to Time Code in time for vid record benderbro Post - Surround - Video 3 12-28-2004 11:21 AM
Digi 002 chase time code? DaleB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-05-2004 10:37 AM
