Old 09-08-2021, 04:45 PM
fdelorme fdelorme is offline
Default Pro Tools 10 (Mac) on a second computer (MBP)
Hello,
I am trying to install my licensed PT10 to my MBP (computer no. 2). I have already PT10 installed on my iMac.
I downloaded the same version as on my iMac. The problem is activation. When PT prompts me to insert my iLok key, it jams and do not respond anymore. No such problem on my iMac.
Is my iLok licence not valid for a second instalment on my MBP? (see screenshot attached)
Thanks for your help.
Francois
Old 09-08-2021, 04:50 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Pro Tools 10 (Mac) on a second computer (MBP)
What OS are you running? PT10 is not working past 10.9.5 and support ended on 10.8.5
Janne
Old 09-08-2021, 04:54 PM
ah! That is the problem. I am running MacOs 11.5 on my MBP.
Which version of PT should I upgrade to then?
I have an older OS version on my iMac. That's why PT10 is running fine!!
Old 09-08-2021, 05:02 PM
JFreak's Avatar
Compatibility info here.
Janne
Old 09-14-2021, 05:39 PM
Additional question.
My iMac can only run High Sierra, so I am stuck with PT10.
I run Big Sur on my MBP. Then, I can run PT2021.
But I am totally confused with Avid subscriptions schemes.
If I switch from my perpetual to a subscription-based plan, will PT10 still work on my iMac?
In other words, with such a 1-year subscription plan, can I keep running PT10 on my iMac and run PT2021 on my MBP?
Thanks again!
Francois
Old 09-14-2021, 06:11 PM
Ben Jenssen's Avatar
Francois, you're not alone in being confused. It's not easy to follow all the license and compatibility rules with PT.
But I'm pretty shure when I say that; if you upgrade your PT10 license to 2021 subscription with 1 year support/update plan, you simply lose the PT10 license. If you buy a new subscription license, you have two separate licenses and you can still run the old PT10. Not shure how that comes out cost-wise.
Old 09-14-2021, 06:16 PM
Thanks a lot Ben. That's very helpful.
F.
Pro Tools Ultimate 2019 and Pro Tools 11 same computer jovictors Licensing & Accounts 1 02-23-2020 01:22 PM
Installing Pro tools M powered LE8 and Pro tools LE8 in my computer yukiaroma Pro Tools M-Powered (Mac) 0 06-15-2012 01:39 PM
Help! Can this computer run Pro Tools? CCtzer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-26-2010 06:40 PM
Pro tools le 8.0 Computer q's kriskuenzler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 03-17-2010 05:09 PM
Pro Tools/New Computer brothertony Pro Tools M-Powered (Mac) 1 06-28-2009 12:37 AM
