Old 06-24-2021, 11:08 AM
Jess Davy Jess Davy is offline
Default Can't save UI Customizations or Presets in 2021.6
It doesn't save Color Palette presets at all. It doesn't create a preset file and also doesn't save quick presets and it looks like they forgotten that they removed Resources section in System Usage window.
Website: www.peakattackstudios.com
YouTube: www.youtube.com/peakattackstudios
iMac Pro 3.2 Ghz 8 Core Intel Xeon W • 32GB 2666 MHz DDR4 • Amphion Two15 w/ Amphion Amp500 • UAD Apollo 8 Duo • UAD-2 Satellite Quad • Avid Artist Mix • Kemper Profiling Amp • BSS DPR-402 Stereo Compressor • Pro Tools 2023.12.1 • MacOS 14.3.1
Last edited by Avid; 07-01-2021 at 01:01 PM. Reason: broken out from the 2021.6 thread
Old 06-24-2021, 11:31 AM
Tweakhead Tweakhead is offline
Default Re: Pro Tools 2021.6
Originally Posted by Jess Davy View Post
snip . . . I also found out that it doesn't save Color Palette presets at all. It doesn't create a preset file and also doesn't save quick presets and it looks like they forgotten that they removed Resources section in System Usage window.
I wonder if they need more beta testers?
I installed, launched, and this is the first thing I found.
I carefully customized the colors to my dark preference, saved it, went to light mode, customized it, saved it.
Went to recall my dark setting . . . uh - nothing there. Wasted my time.
What a great feature.
Edit: Update . . .
Actually it does work. You just shouldn't use "Save Settings As" first time around.
You must use "Save Settings", then after that you can use "Save Settings As".
While editing a UI Theme parameter, Page Up/Down in the Edit Window does not work.
Old 06-24-2021, 02:08 PM
Benny Mouthon's Avatar
Benny Mouthon Benny Mouthon is offline
Like the header says..
I change the UI settings, SAVE or SAVE AS and give the file a name
but it doesn't save the file in the COLOR PALETTE folder.
Similarly, I can't apply the settings to a 1-5 preset (command+click), just resets it all to the default settings.
2018 MacMini, 10.14.6
Old 06-24-2021, 02:10 PM
Default Re: Can't save UI Customization settings..
Yeah. Several others have found this to be the case.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 06-24-2021, 02:17 PM
Somebody over on Gearspace (used to be Gearslutz) is saying that any color change presets one makes are not being saved. Haven't tried it - just mentioning what I'm seeing there. Does anyone know if they're global or per session?
Jack
QAPLA!
Old 06-24-2021, 03:18 PM
tones tones is offline
+1
Old 06-24-2021, 03:46 PM
massivekerry's Avatar
massivekerry massivekerry is online now
Agreed.
I tried saving it to a new (Mac) folder, but interestingly enough, I got this message. So, maybe there was a bit of code that needs to have its Text String changes? PS - I tried making a new folder in there called "Window Presets". Pro Tools didn't like that either.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 06-24-2021, 03:55 PM
Default Re: Dark mode forum thread request
The Color Palette changes won't save, but I may have found a hint when I tried to Save them to a newly-created subfolder (on Mac). Check out the attached Error Message.
Kerry Smith
Old 06-24-2021, 05:35 PM
hey musicman, I already posted how to solve it earlier in this thread :
https://duc.avid.com/showthread.php?...60#post2605260
Old 06-24-2021, 05:56 PM
mattrixx mattrixx is offline
They are saving for me (remember to command + click on one of the five preset buttons, like we do for zoom and clip effects presets).
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Can't save any plug-in presets SomeOtherGuy Pro Tools 2020 5 03-11-2021 09:42 AM
The presets in the workspace window don't save... Arno Peeters Pro Tools 12 4 06-11-2017 08:43 AM
Workspace view presets don't save travistko Post - Surround - Video 10 02-15-2017 06:08 AM
Control 24 customizations Noizetrip ICON & C|24 21 12-09-2011 10:34 AM
Master X3 won't save new presets macaholic Post - Surround - Video 2 01-14-2008 09:53 AM
