Old 08-18-2006, 09:35 PM
brawn brawn is offline
Default popping when selecting sections of regions
Im new to pro tools. Ive noticed there is sometimes a popping and sometimes no popping when
I select a portion of a region to loop. It seems random to me. Is there a way to ensure the edit contains no
popping.
I thank whoever answers.
Brawn
Old 08-18-2006, 10:11 PM
kelsey's Avatar
kelsey kelsey is offline
Default Re: popping when selecting sections of regions
It sounds like to me, the popping you are hearing is because the start/finish of the selection you made is not at a zero crossing. You either need to adjust the start/finish of your region selection to coincide with a zero crossing, or cut the region and fade it if moving the edit point is not an option. An easy way to visually check if your edit hits a zero crossing is to zoom in really far and look at the waveform. Hope that helps.
Peace
Kelsey
https://wanderingear.net
Old 07-22-2008, 09:35 AM
flang1954 flang1954 is offline
Default Can PT be set for zero crossing automatically
Hello,
I'm new to Protools also but I have used a number of other DAWs. Is there any way to set PT to automatically do a zero cross at edit points/ Seveeral other systems offer this feature. Do I really have to hand adjust or crossfade every edit?
The program seems a marvel in many ways but redoing each edit seems a little like tedious torture. I'm hopeing I just can't find the setting yet. Thanks all.
Old 07-24-2008, 06:25 AM
Default
I found out (through others here) that an option is to
Select region which includes all the edits and hit Command+F for a 4ms fade on all the edits.
(just the f key in keyboard commnd focus works the same for the sake of us newcomers to the program)
Cannot select sections of regions watasnake Pro Tools M-Powered (Mac) 3 01-31-2010 05:53 AM
PT not selecting and highlighting Regions Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-18-2009 03:02 PM
can I create multiple regions into 1 bar sections ellmanl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-22-2005 12:18 PM
selecting regions... neonknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-05-2004 10:34 AM
selecting tracks or sections of tracks drummerfreak33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-24-2004 01:33 PM
