#41
Re: 7.1cs3 & spinning ball of death whith crossfad
I've also observed that I've only encountered the BBOD in certain sessions delivered from one client who worked on firewire drives, then transferred to a backup drive that was sent to me. I then transferred the sessions to SCSI drives before mixing. This may be noteworthy because every so often I get a CD or DVD with data that seem to have been corrupted somewhere along the way when transferring or backing up to different media. FYI I just experienced BBOD when attempting to Make Inactive an audio track. I tried both the keyboard shortcut and the menu, both unsuccessfully, and was unable to force quit, so I had to power-cycle the G5 to get back to business. I'm on PT 7.1cs3, OS 10.4.3, SCSI 128 Kit, 13-slot chassis, HD4 Accel, and no FW drives were connected during any of these experiences.
Michael James michaeljamesproducer.com www.IndieProMix.com System info: PT Ultimate 2019.6 HDX, Mac Pro 5,1 Westmere, OS 10.13.3, UAD2 Octo PCIe, 2x Lynx Aurora16 w LTHD cards, 1x Lynx Aurora(n) 32 ch analog I/O DigiLink, 4x Dangerous Convert-8 (AES via Lynx), Dangerous Convert-2 (AES via Lynx), Dangerous Vonvert AD+, Apogee Big Ben, SSD boot drive, external FW800 audio drives |
#42
you have your money for the 7.0 now all the hard drives are initialize and the plugins are authorized and our clients look at their watches everytime we crash doing a fade...which is often i save before every fade now. it is hard to work with a clear mind in fear and worry of the next crash...... PLEASE......take some of that money we gave you and get more staff who can fix what you have sold us quick.....this is costing us much money and embarassment. i asked about this problem at NAMM and no one knew a thing but waves didn't run 7.0 on their exhibit so i smelled a rat . . . . we love you and are counting on you..... i mean what else can we do this IS The spot between the rock and the hard place.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
#43
We are working on this as quickly as possible, unfortunately I do not have a specific ETA, as we are still in testing.
In the meantime, the workaround is to use a fade command that does not bring up the fades dialog - either by using cmd+ctrl+f or putting it into commands focus and using the 'f' key to apply the fade. |
#44
#45
Actually, we've been using the "f" key to create the fade for a few weeks now (I had started a similar thread a while back). If you need to change the fade shape, double-click on the fade and that will bring up the dialog box without the spinball. Perhaps we've been lucky here, but not a freeze ever since.
Marco Marinangeli Magelic Productions, Inc. Compression Records http://www.compressionrecords.com |
#46
And even though I haven't had the problem with fades like others (I can perform any fade without problem), by virtue of following this thread i've rediscovered the Fade dialog after years of heavily relying on the Smart tool. |
#47
NOW there is the new PT HD 7.1cs4 release!! Try it!!
Mac Pro (Mid 2010) Six Core 3.33GHz macOS 10.14.6 MSI Radeon RX 560 Pro Tools | HDX, HD I/O 16x16, HD I/O 8x8x8 Pro Tools Ultimate 2022.9 MacBook Pro (Mid 2012) i7 2.3GHz macOS 10.15.7 Pro Tools 2021.12 Apogee Duet |
#48
Hi I just updated to 7.1cs4 and now get this message when trying to create fades
'one or more fade requests are invalid due to insufficiant data within fade bounds. You may skip the invalid fade request(s), or adjust the bounds for those fades(where possible).' could somebody translate this for me into plain english and any suggestions for a solution would be appreciated thanks
#49
B. |
spinning beach ball of DEATH vs. PTLE | Chickenhawked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-24-2010 10:42 AM |
HELP!! I save... spinning ball of death... what the.. | indiemusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-19-2009 03:41 AM |
Spinning Beach Ball Of Death On G5? | logandrum | Pro Tools TDM Systems (Mac) | 0 | 08-03-2007 12:07 AM |
7.1cs3 & spinning ball of death whith crossfade | drums77 | Pro Tools TDM Systems (Mac) | 1 | 02-03-2006 08:56 AM |
spinning beach ball/curtain of death! | bruce lang | Pro Tools TDM Systems (Mac) | 2 | 02-11-2005 12:42 PM |
