Old 05-22-2019, 03:30 AM
rcutz rcutz is offline
Default Re: 2019.5 questions
Jeff one question: the shortcut: "control +select on track on the console" was replaced?
I use it a lot. My workflow is based on layouts, so when I change the layout from Dial to Efx for exemple, I usually do this shortcut to scroll the session to the tracks on the console at the moment. Now this shortcut "was missing" on 2019.5.
best.
r.
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Old 05-22-2019, 04:29 AM
creativecontrol's Avatar
Greetings,
That’s very odd as I have it working here currently:
Recall a layout either 1:1 or in a Spill Zone.
Hold Shift and Control modifier switches on any Fader module while pressing a channel’s Select switch. This also works from the Tracks page on the Master Module. Pro Tools will scroll and justify this as the top track in the edit window or leftmost channel in the mix window.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-23-2019, 07:42 AM
Jeff. "shift +control + select track" worked. So the shortcut change.
Ricardo Cutz
Http://106db.com.br
Old 05-23-2019, 07:55 AM
Yes, sorry about that. We aligned the Pro Tools shortcut with the surface shortcut, which I believe makes a lot of sense and keeps it cleaner. Whether you perform Shift Control clicking on a track in Pro Tools, from the Channelstrip on S6 or from the Tracks page in Select mode - you will trigger a scroll and justify into place.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-23-2019, 10:37 AM
RedRock RedRock is offline
I have no metering on my M-10 since the upgrade. Is there some kind of preference I'm not seeing?
Old 05-23-2019, 10:53 AM
The first thing I would check would be the firewall settings on your Mac. Is firewall enabled? And if so, is WSControl allowed to get through in the advanced settings? Also, are you on Mojave?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-23-2019, 11:30 AM
No Firewall. Yes I'm on Mojave. Everything else works fine.
Old 05-23-2019, 11:43 AM
Thanks. A few things to check...
(1) It is highly recommend, if you haven’t already done so, to run the uninstaller for EUCON 2019.5 to remove any previous versions. Once you finish that, re-install WSControl and reboot.
(2) How many NIC’s do you have on your workstation and what is the service order for them?
(3) Are you using the built in DHCP server on the MTM, and if so, on what Ethernet port on the back of the Master Module?
Thanks,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-23-2019, 12:05 PM
I did a clean install last week. I did it again today and it fixed it.
Thank you.
Kent
Old 05-28-2019, 06:44 PM
laki laki is offline
Is 2019.5 compatible with Pro Tools 2018.3?
Wont be upgrading PT for a few weeks but thought I'd get started with the desks.
I figure that some of the new features won't be available.
2019 Gui Lag manfromspace Pro Tools 2019 7 06-20-2019 01:59 AM
2019.8 amagras Pro Tools 2019 89 06-10-2019 12:40 AM
PT 2019.5 with OSX 10.13.6 jyamada0 macOS 5 06-09-2019 02:29 PM
Pt 2019 paldry Pro Tools 12 7 05-12-2019 04:18 AM
