Fast Track Ultra and Windows 10 Problem
I was using Fast Track Ultra with Windows 7 with no issue/ Ever since I have changed over to Windows 10. I continue to get an error that says "Device power state failure". I am suspecting that it is the Fast Track that windows does not seem to like. Does anyone have any suggestions?
I attached a screen shot of what the device manager drivers look like for the Fast Track Ultra Thank-you |
Re: Fast Track Ultra and Windows 10 Problem
Is this on the same computer, same USB port that was working in Windows 7? Could you try a powered USB hub? Or a power adapter?
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Thanks Joel. Yes, it is on the same everything. At present, the Fast Track Ultra is wall powered (plugged into an electrical outlet) and the usb is going to a usb port that is inside the PC, so it is not a hub or anything. I am assumign it is the fast track ultra, but I could be wrong.
Thank-you for the suggestion. That could have been a good solution if it was not for the fact that the unit itself is wall powered. |
It is possible something is going in the FTU. I'd try it on another computer if possible and see if you have the same issues.
If it is a physical problem with the FTU, it would probably be more cost effective to look for a newer interface to upgrade to. Joel
Hello.
With the transition to Windows 10 had problems with the M-Audio Fast Track Ultra. (Windows 10 x64, Driver Version 6.1.10) Sound periodically disappears. It helps to get it back only off / on the device. USB-cable tested, connected to another USB-port, fully reinstalled drivers. To no avail. I know in at least two more people who have the same problems with the device. In this case, the Mac OS X device is stable, no problems there. Also, sometimes when working in Studio One sound begins to "stutter." It helps again only off / on the device. Please help ... |
I still have the problem I described above, but once I restart my PC, I am able to use the FTU without any problem.
SoundD- I would suggest you try resetting all your configuration settings to factory settings on the unit. The stuttering sound you describe sounds more like a problem wit buffer setting between your DAW and the FTU than a hardware problem with the FTU |
It still sounds to me like a buffer issue. I began having the same problem when i updated my fast track driver to the new one - you know, the one that has a nicer interface (GUI-like). When I used that version, I got the stuttering.
I reverted back to the basic driver that i had used before. This was not easy, as the computer, for some reasons, always wanted to reinstall the latest driver. I finally figured out how to get rid of the latest driver, and revert to the previous version. Although it does not look as nice, I have not had the stuttering problem since. I also reinstalled Pro Tools at the same time. I hope this helps. I know how maddening that can be. It took me a few weeks before I figured it out. |
Which version of the driver you have installed?
Fast Track Ultra and Windows 10 | ptauger | FireWire & USB Audio Interfaces (Win) | 3 | 01-28-2016 12:18 PM |
Fast Track Ultra 8R Windows 10 drivers? | Amechan | FireWire & USB Audio Interfaces (Win) | 9 | 11-15-2015 11:52 PM |
Fast Track Ultra Windows crashes | ducknoir | FireWire & USB Audio Interfaces (Win) | 0 | 06-15-2015 05:51 PM |
Fast Track Ultra Driver 6.1.10 Won't Install Windows 8.1 | manonash | FireWire & USB Audio Interfaces (Win) | 0 | 11-23-2014 01:03 PM |
Fast Track Ultra on Windows 8 x64 | mcrooney | FireWire & USB Audio Interfaces (Win) | 4 | 04-27-2014 05:08 AM |
