#21
Re: PT 9.0.5 with Lion - unable to open other MIDI apps open as standalone
I know it has been awhile, but after speaking with a senior technical support representative for nearly 3 hours a couple of weeks ago, we were still unable to resolve the problem with the DigiDioMidiDriver crashing every other application that accesses MIDI (including Audio/MIDI Setup). His only other suggestion was for me to wipe my computer clean and reinstall everything from the ground up, which is what I have done.
Nonetheless, after reinstalling the latest versions of everything and checking on their official compatibility status, I regret to inform you that the DigiDioMidiDriver still causes every other application to crash. Below is a list of applications I have had crash with this driver installed: Audio/MIDI Setup Live 8.2.7 Logic 9.1.6 Reason 5.0 Has anyone else had any luck with resolving this problem? Thanks, Zach |
#22
Cheers |
#23
I need to use the 002 midi ports so deleting the driver is not an option. DIGI SUPPORT - when will this be fixed in PT 9?
#24
BUMP.
I just purchased a new machine with OS-X Lion and was excited to get my outboard synth gear running through my 002 as well as my midisport 2x2 anniv. ed. Turns out that neither have functioning drivers in Lion. I am able to recognize my interface in Lion, but midi i/o window reports an error Quote:
after installing the 002r standalone driver, (002 and 003 Driver 9.0_r3.mpkg) I get the above quoted error. Its frustrating to have a couple thou in synths and not be able to interface with them. I can be patient, but give us some hope. thanks Dave |
#25
Best solution
Buy a new audio interface (any really) and leave the 002 and 003 for the museum
Just Run Pro Tools as a Rewire Slave/Run Parallel.. its easier than you think. Example- RME TotalMix and the IAC Midi Driver http://duc.avid.com/showthread.php?t=313749 |
#26
I have that same problem when I try to use Finale. I'm running PT 9.0.6 and I have to open PT first or Finale won't open. It stops at "initializing core midi". After I open PT with Finale I can close PT and I can still access Finale, but if I quit Finale I have to open PT again.
#27
So you're saying that the OS doesn't initialize/activate the Midi ports until you open up a PT session? does that report as well in your audio-midi setup? I am assuming that you're running this on some recent variant of OS-X...
I will have to give this a try. Quote:
#28
Bump. Also having the same issue, crashes in DigiDio. This renders the MIDI ports on my 002 Rack completely useless. Same old same old from Avid.
I'm actually just re-installing Pro Tools after a hiatus since I lost my iLok and got so fed up with the Digi support mess that was trying to get it fixed I couldn't be bothered. I finally managed to get my licenses transferred to my iLok last night and end up with this... |
#29
I was having these same problems on my new MacBook Pro and Lion 10.7.2
I fixed it by having the Apple Store put Snow Leopard 10.6.8 on there. Everything is working now; PT, Logic, Ableton, Peak, & Serato for me.
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2 redtuxedo.com milkmoneyconsulting.com mindexpansiontechnology.com |
#30
Unable to open Sessions (Tracks unable to load) | palmify91 | Pro Tools 10 | 1 | 03-27-2013 08:00 AM |
PT9.0.6 Won't Open in Lion 10.7.2...?? | tomhartman | macOS | 2 | 01-08-2012 11:27 AM |
Avid midi driver with lion make all other apps using midi hang!!! | TREXROCK | macOS | 4 | 10-30-2011 05:39 PM |
Unable to open Midi Studio Setup | yvan | Pro Tools TDM Systems (Mac) | 8 | 08-25-2005 03:55 PM |
Digi CoreAudio vs. other open apps | jes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-30-2003 10:09 AM |
