Old 01-23-2010, 11:04 AM
smurfdaddydog smurfdaddydog is offline
Default Help! just upgraded to HD and IK is causing problems
OK, I did the upgrade but my favorite IK plug ins (amplitube 2, specifically the Vai solo patch) will on occasion lock up pro tools and shut it down. I run a pre intel G5 quad with the latest updates supported and ran the test that says everything is working right. None of the other plug ins seem to cause this problem. Any ideas? Really... anything would be appreciated.
Old 01-23-2010, 11:34 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Help! just upgraded to HD and IK is causing problems
What operating system? what PT version?
Have you uninstalled / removed amplitube then trashed prefs to empty the cache!! the re-installed Amplitube?
Check if there are any IK or Amplitube preferences in your user/library/prefs
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-25-2010, 10:36 AM
stanonbass stanonbass is offline
If your running a quad core mac on protools 8 the problem most likely is your running 4 processors. Go into playback engine and change the processors to 2 and the IK stuff wont glitch and crash.
A lot of the plugs dont like more then 2 processors.
Upgraded PC causing terrible noise with Digi 002 console Fredy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-19-2013 09:36 PM
ATI Is causing all the problems! scott_ven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 05-17-2006 09:24 PM
Two Problems.. Just Upgraded to 6.7 CS8 from 6.4 tonicjeff Pro Tools TDM Systems (Mac) 4 02-24-2005 09:23 PM
IRQ conflicts causing BTD problems? gtrguy4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-10-2003 08:26 PM
The 001 causing problems with DP gavspen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-29-2003 09:27 AM
