Old 08-24-2005, 03:45 AM
yvan yvan is offline
Default Unable to open Midi Studio Setup
I've been trying to re-open the MidiSetup for days now and nothing happens, dun it before without any problems and didn't update or changed anything since, it just occured suddenly with no reason.
Re-installed protools, oms, Midi IO firmware, checked all the cables and so on...
The window simply won't open
I've read another topic mentionning this problem and followed DigiTechSupport's advice (trash certain files in the prefs), but still no improvement
This is getting really annoying and I'd appreciate some help,
thanks
G4/HD1, 192, Sync, Midi I/O
Soundcraft Ghost 32ch
Old 08-24-2005, 06:12 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Unable to open Midi Studio Setup
What system setup do you have? list it all! mac os and pt versions etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-24-2005, 06:29 AM
I'm running PT 6.2.3 on a g4 dual 1.25, HD1, Midi IO with latest driver
Old 08-24-2005, 06:41 AM
crizdee's Avatar
What mac os?
Producer, Engineer,
www.ukmastering.com
Old 08-24-2005, 07:01 AM
sorry forgot about that :OS X 10.3.9
note: everything worked before with this setup and drivers, I didn't apply further updates or modifications and one day it just didn't wanna show up anymore
Old 08-24-2005, 08:34 AM
DigiTechSupt's Avatar
Yvan -
Which specific preferences did you trash?
It's always a good idea to be specific about what you've tried so far, so that further troubleshooting can be done immediately.
Avid Audio Tech Support
Support FAQ
Old 08-24-2005, 10:13 AM
crizdee's Avatar
You don't need oms!
Can you open the AMS (audio midi setup) from the desk top without pt open? its in applications/utilities
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-24-2005, 01:26 PM
mixer mixer is offline
10.3.9 is not approved for digi.."Mac OS X 10.3.9 has not been fully tested with Pro Tools and is not recommended". does the midi setup appear ing the applications utilities folder on your mac drive..and can you setup from there?
www.garyvandy.com
Old 08-25-2005, 03:55 PM
Yvan -
"com.apple.audio.AudioMIDISetup.plist (User Folder/Library/Preferences)"
this and 2 other files located in library, can't remember wich ones but they were similar to this one above
PT 9.0.5 with Lion - unable to open other MIDI apps open as standalone Rebel macOS 29 05-22-2012 10:49 AM
unable to setup MIDI instruments through Mbox 2 Pro MIDI port tomazbevilaqua 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-30-2010 06:04 AM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
I can't open the MIDI studio setup moiblest3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-24-2005 10:00 AM
All MIDI is inactive when opening a session, until i open OMS Studio Setup and...... Mt.Everest Pro Tools TDM Systems (Mac) 3 04-03-2001 12:37 AM
