6.7 Timecode generation problem
Has anyone else noticed that when generating code the disk activity doubles?
We had noticed this in 6.4 and earlier versions when the Tempo Map had changes in it but it seems to be there all the time with 6.7. Method: Newly initialized SCSI disk. New session 48 track 24 bit. Record all 48 without generating code gives about a 50:50 access to the disk. Putting on-line and generating code the disk just about maxes out. G5 Atto UL4D OS X.3.7 PT 6.7cs5 OK I know that this is not a 'compatable' set up, but I suspect that this will be the same with our 'compatable' G4 and G5 systems when I can get access to them to try it out. It was with our earlier v6.4 experiments. |
Re: 6.7 Timecode generation problem
Sorry, I forgot to say it only happens when in record. There is no problem when in replay.
I have had problems with this exact same scenario. This is a critical issue which needs to be addressed.
At last someone else has seen this !!!
There was also a problem in 6.4 if the Tempo map was altered. I have been able to demonstrate this in 6.4 to a Digidesign Technical Support engineer who came to the studio, and when I realised that it is there all the time in 6.7 I have not put out 6.7 for general use. I have reported it to Digidesign Support on the email form and have had no reply, and I also phoned the US support line and I was assured that it would be pursued, but I have heard absolutely nothing back. |
Actually I think the title of this thread is incorrect. It should be just "6.4 Timecode generation problem".
Yes, 6.7 has problems ALL the time while recording, but it does not appear to be related to timecode generation. Either way, I am now totally screwed if I need to simultaneously record a lot of tracks while generating code - as neither 6.4 nor 6.7 is capable. And since I recently upgraded my HD to Accel I can't even go back to OS9 in an emergency. |
Problem Mbox Pro 3rd Generation - HARDWARE NOT CONNECTED | Zangra | FireWire & USB Audio Interfaces (Mac) | 0 | 08-21-2013 04:42 AM |
AJA IO HD Pro Tools Timecode Problem | bommimann | Post - Surround - Video | 3 | 11-13-2008 08:37 AM |
Timecode chase problem | cpunthank | Post - Surround - Video | 2 | 09-15-2005 10:56 AM |
Timecode problem ... | Mr Peete | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-24-2001 02:27 AM |
overnight timecode problem | audiokraftwerk | Pro Tools TDM Systems (Mac) | 1 | 03-14-2001 06:51 AM |
