Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 10-19-2021, 03:20 PM
[email protected] santanamarkblue@yahoo.com is offline
Default Mixing in Pro tools
When download samples or audio sound do you create a folder separate from the hard drive and put it on your desktop or screen?
Old 10-20-2021, 07:49 AM
Default Re: Mixing in Pro tools
Don't put your work on the desktop, because when you boot the computer, it has to load every file on the desktop(which slows down boot time by a lot). To really get the best answer, consider a few things:
1-the purpose of the downloaded file. If its to use in 1 particular session, I would move the file into that session folder and import from there(there are a few reasons for this, but suffice to say, you will always know where that file is(every one of us has misplaced files before we learn some hard lessons).
2-If the file is to be used in many projects, I would create a folder for samples(preferably on a separate drive) and copy FROM that location into any sessions that need that clip.
3-regarding drives in general, if your computer only has a single drive, it should be an SSD for best performance(many laptops use a 5400 rpm spinner, which is too slow for any serious recording. A 7200 rpm drive is better, but with an SSD, its feasible to record with only a single drive(no matter what drive you record to, you need to back everything up on a regular basis unless you don't mind losing your recordings)
DJ mixing in pro tools dsonic715 Pro Tools 10 2 08-26-2012 08:35 PM
5.1 mixing Pro Tools 10 mbt.fair Pro Tools 10 3 04-23-2012 03:29 AM
Mixing Pop In Pro Tools nod25 General Discussion 2 08-06-2009 11:34 PM
5.1 Mixing for Pro Tools LE torquemada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-26-2007 01:18 PM
Pro Tools Mixing exegesis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-04-2003 04:25 PM
