Old 10-13-2021, 06:25 AM
scramble's Avatar
scramble scramble is offline
Default Why does Pro Tools keep forgetting settings of the AIR Dynamic delay plugin?
I've started to have problems with Pro Tools not saving the settings of the AIR Dynamic delay plugin. All other plugins seems to work fine and settings are saved with the sessions.
Problem description: I open a new session, or an old one, and insert the AIR Dynamic delay plug and adjust the settings of it. I close and reopen the session and the settings are back to factory preset.
I've tried: Thrashing the settings folder. Automation is turned off for the channel, so I can't see that it could be that that messes something up.
I've been able to use the plug and save the settings earlier. I mostly do video sound, so I don't often use the delay plug -- not sure exactly when this started to be a problem.
What more could I check? Could it help to reinstall the plug?
I'm on Pro Tools 11.3.2.
Old 10-13-2021, 08:15 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Why does Pro Tools keep forgetting settings of the AIR Dynamic delay plugin?
There were some versions, and I cannot remember which ones, where PT forgot the preset name of what you last used. It however kept the plugin settings intact, so please test if this is the case. Put a plugin into a channel, factory reset it, change one setting to extreme, save your settings to "test", last close/reopen and see if what I said holds true: the setting should be the extreme one (not factory default) but the preset name is forgotten.
Janne
HDX 12.7.1 forgetting delay compensation algroves Pro Tools 12 19 04-27-2017 04:56 PM
Air Dynamic Delay: Can't save settings dg27 Pro Tools 11 0 12-20-2016 02:45 PM
DDLAY-a new free dynamic delay plugin WorldStudios AAX Plug-ins 46 02-14-2016 10:25 AM
Plugin settings, Delay, PTLE 5.3.1 Vegadark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-04-2002 12:13 AM
