Old 12-02-2016, 05:03 AM
bassmagnetic bassmagnetic is offline
Default cascaded send and plugin menus overflow offscreen PC
when I click on a send to select a new routing (or plugin to select a plugin) and the menu of all the send routings (or available plugins) is displayed, they overflow further than the screen, so it is not possible to see the list in order to choose a routing. If I use the arrow keys the cursor will go off screen but the list doesn't scroll.
There used to be a small arrow at the bottom of the visible list so that I could scroll, but now this isn't there, also mouse scroll wheel doesn't work on the list.
This behavior has been happening over a few PT versions. I'm currently on 12.6 and using a PC win8.1. The displays are correctly setup within the os.
Anyone know any workaround?
Old 12-02-2016, 05:08 AM
Drew Mazurek's Avatar
Default Re: cascaded send and plugin menus overflow offscreen PC
What is your screen res set to? How many pixels high?
www.drewmazurek.com
Old 12-02-2016, 05:31 AM
1920 x 1200
Old 12-02-2016, 05:46 AM
1920 x 1200
1200 should be plenty.
Are you doing any sort of "zooming" or scaling in the OS? Sorry, I don't know anything about Windows, but I've seen this mentioned here in the DUC.
www.drewmazurek.com
Old 12-02-2016, 05:56 AM
Nope no zooming or scaling
I have 3 monitor setup
Old 12-02-2021, 10:41 PM
Songster Songster is offline
I have a 2 monitor setup, and I'm having the same issue. I've submitted the problem to AVID and have been going back and forth. This especially happens when I'm on the bottom screen and try to add a WAVES plugin. It's gotta be in the programming because the AVID plugins bring up the scroll arrow. Something about how 3rd party plugins and PT are communicating that's broken. Hope it gets fixed ... it's annoying for sure. Right now whenever I want a Waves plugin added, I have to do it from the top display, which is usually the edit window.
Old 12-03-2021, 07:29 AM
This inconsistency has been in place for quite a while. On my own system(these days), I usually find the little arrows for scrolling. But ever since we got the "search" option for plugins(and sends), I never need to scroll. Just search and go
Inspiration overflow... Stig Eliassen General Discussion 0 10-09-2011 04:52 AM
Soft Keys and right-click menus Picture Start Artist Series 2 11-16-2010 02:26 PM
Regions list overflow bug? Blacklight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-14-2009 06:59 AM
Integer Overflow waxboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-08-2006 10:12 PM
overflow and underflow out of the gates bretstamper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-04-2004 12:56 AM
