Old 11-06-2010, 11:40 PM
bruce lang bruce lang is offline
Default encoding question
When encoding a 5.1 mix to AC3, what size would the typical file be? I've been playing some with a version of Apack, 6 20MB files were compressed to a 10MB AC3, just wondering if that's about right.
Old 11-07-2010, 02:59 AM
tom_lowe tom_lowe is offline
Default Re: encoding question
Depends on the bit rate, but for a 6 channel AC-3 file, the data rate should either be 384kbit/sec or 448 kbit/sec. Once you know that, the calculation is easy.
Remember a 2 channel uncompressed PCM at 24/48 is around 2.4Mbit/sec.
Old 11-07-2010, 04:02 PM
Thanks for the reply, I just wanted to make sure the AC3 process was supposed to compress the wav files, even though the apack compression options were turned off. I've read in previous posts this was the thing to do. I'm just looking to make an DVD-video with some surround mixes I've made in PT to see how they sound on my home entertainment setup.
Old 11-07-2010, 07:31 PM
Postman Postman is offline
Yes,
AC3 compression reduces the amount of data by quite a bit, its whole reason to exist. I haven't done the math but what you've posted sounds totally reasonable.
Don't confuse audio dynamic range reduction (compression) with data reduction (compression). They are unrelated operations.
Old 11-08-2010, 03:07 AM
Thanks much.
HTML code is On
PT9 and MP3 Encoding question spinsah Pro Tools 9 4 12-11-2010 12:37 PM
AC3 encoding? KingTor Post - Surround - Video 4 10-01-2009 04:54 PM
5.1 DVD Encoding tandem Post - Surround - Video 1 03-10-2005 03:25 PM
encoding question tokyofan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-05-2004 07:11 PM
Dolby LCRS encoding question for Sundance georgia Tips & Tricks 1 09-01-2000 10:05 PM
