Old 03-08-2025, 06:05 AM
cmbourget's Avatar
cmbourget cmbourget is offline
Default Keyboard shortcut problem or bug
I try to modify a keyboard shortcut corresponding to the option to hide/show all floating windows. I choose F16. However, if I do this F16, I see the windows appear and then suddenly (a 100th of a second) close. The same thing happens with the Color Palette if I try to change the shortcut to =. However, everything works from the menu, where the assigned shortcut is clearly visible. On the other hand, the list of shortcuts shows no conflicts with these keys.
Does anyone have an explanation? (I'm on a Mac with a multilingual Canadian keyboard)
  • Pro Tools Ultimate 2024.10, Nuendo 13, Samplitude Suite Pro X7, Wavelab 11, SpectraLayers 11, Dorico Pro 5, Melodyne studio 5.
  • Apollo X 16 Heritage and 7.1.4 studio (Focal Solo6 be X3, Focal Sub6 Be, Focal EVO 65 X 4 and Focal EVO 50 X4)
  • Softube Console 1, Avid Transport and iPad Pro 12.9" for Avid Control.
  • Mac Studio M2 Ultra 2023. 2T. 128 Go. + 2X 4 T NVMe ext.
  • Roland V-Piano, Kurzweil SP88
  • Etc.
  • www.claudemarcbourget.com
Old 03-11-2025, 05:34 AM
reneo reneo is offline
Default Re: Keyboard shortcut problem or bug
Yep, same bug overhere: using Mac Studio M1max running macos 15.3.1. Happens only on custom keyboard shortcuts, also for shortcuts for show/hide Names in clips
I'm back using App Keyboards Shortcuts in the system preferences pane.
Apple MacStudio M1 Max, MacMini M2 Pro, MacBook Pro M1 Max
MacOSX 10.14.5
Pro Tools Ultimate 2024.6
Apogee Symphony Desktop
Old 03-11-2025, 05:44 AM
tope d's Avatar
tope d tope d is offline
I tried to reproduce but I was unable to.
Currently on M3 OS15.3.1. PT 2024.10.2
Can you post a screen recording of the workflow?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-12-2025, 02:21 AM
Of course, see this wetransferlink.
MacOSX 10.14.5
Old 03-12-2025, 08:54 AM
cmbourget's Avatar
As soon as I have time, because I've changed my shortcuts because of this bug and I'll have to redo them.
  • Etc.
Old 03-21-2025, 03:09 PM
cmbourget's Avatar
There really is a problem with one-key shortcuts. I'm now trying to configure the mute/unmute of a clip with the single “M” key. I press “M” once and it shows PT Mute and Unmute. Exactly as with the = key for the color palette, as I mentioned at the start of this thread.
I should add that the shortcut menu shows no conflict and that if you go to the Edit menu, where my shortcut is shown correctly, and do MUTE, it works. It's really about the keyboard.
p.s. I tested it with another Mac keyboard, this time wired, and it's the same. But if I create the shortcut with “ù” (French keyboard), it works. Update : Another bug. In addition to mute and unmute the clip, the same key changes mode at the same time ((SHUFFLE-SLIP-SPOT-GRID). Big problem! And if I remove this shortcut by resetting it, the “ù” alone no longer does anything. What's that supposed to mean? A disorder in the programming.
  • Etc.
iMac Keyboard Shortcut problem Drafter macOS 10 01-14-2011 08:44 AM
Alt+[ keyboard shortcut problem Samuca123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-27-2009 01:49 PM
Keyboard shortcut problem idris Pro Tools TDM Systems (Win) 1 02-15-2009 09:51 AM
protools le7 keyboard shortcut problem joen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-15-2006 01:53 PM
keyboard shortcut problem(s) buddyerkin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-07-2005 09:11 AM
