Old 06-17-2014, 05:54 AM
robotboy robotboy is offline
Default Used MacBook for PT 8/Mbox2??
Can anyone recommend which kind of used Macbook I would want to buy to run PT 8.05 with an Mbox 2? I've always been a PC guy and don't know much about the Mac, or any computer for that matter! Thanks
Old 06-21-2014, 10:59 AM
mindnoise mindnoise is offline
Default Re: Used MacBook for PT 8/Mbox2??
You biggest problem will be OS-Combatibility with the 3rd party Plug-Ins but here you go:
here is the official PT 8 requirement doc from AVID:
http://avid.force.com/pkb/articles/e...ility/en363239
and here a sheet which Version of Pro Tools and MBoxes are ccompatible with which Mac OS:
http://avid.force.com/pkb/articles/e...ility/en353149
the highest Mac OS that is officiall compatible with Pro Tools 8 is 10.6.8 (Snow Leopard) in 32 Bit Mode
(PT 8 can be made compatible with OS X 10.7 Lion but this might be too much of a hack for you:
http://duc.avid.com/showthread.php?t=306237
Subsequently you need a MacBook (Pro) that can still boot into 32 Bit Kernal.
the latest MacBooks (Pro) that were shipped with 10.6.8 are e.g. the early 2011
15" and 17" models
15":
Introduced February 2011
Model Identifier MacBookPro8,2
Model Number A1286
EMC 2353
Order Number MC721LL/A (2.0 GHz) MC723LL/A (2.2 GHz)
17":
Model Identifier MacBookPro8,3
Model Number A1297
EMC 2352
Order Number MC725LL/A
So, basically you can get any MacBook (Pro) between 2007 (earlier is not recommended, the technology is too old)
and 2011, without worrying.
Anyway, here is a article on until what Mac Revision OS X 10.6 can be installed - look at the very end of the article:
https://discussions.apple.com/docs/DOC-2455
"MacBook Pro 8,x with EMC#s 2355, 2563, 2564 can only run 10.7 or later, all other 8,x EMC#s can run 10.6.3 or later, and all 7,x can.
MacBook Pro 9,x and higher can only run 10.7 and later."
And finally MBox 2 drivers:
as far as the MBox 2 compatibility is concerned there are drivers that support even the latest Mac OS 10.9 (Mavericks)
http://avid.force.com/pkb/articles/e...ers&popup=true
sorry that there is no shorter way to informing you but I don't see any easier way but I hope this helps,
last: PT11.3.1
MacBook AIR and Mbox2/PT8 DiegoFox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 01-18-2011 06:48 PM
MBox2 Pro with New Macbook Pro allim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-31-2009 12:42 PM
Macbook with Mbox2 pro Papawhitehead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-28-2008 08:45 PM
Macbook 1.83ghz Core 2 Duo and Mbox2/Mbox2 Pro fhqwhgads 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 12-12-2006 09:23 PM
Mbox2 + MacBook Pro + DP dan wool 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-01-2006 10:25 AM
