Old 04-20-2003, 02:09 PM
The Chinese The Chinese is offline
Default Re: Protools 6.01 Sudden Quit/Crash....
tried JCC No help.
Anyone else?
-Todd A.
Old 04-20-2003, 07:54 PM
I am not using v6 yet, but if you're confident you've tried everything (and I read it as you are), then I'll propose the following:
Do you have crashreporter enabled? If so, you'll have a log file of the crash located in Macintosh HD:Users:<your user name>:Library:Logs, and it will probably be named "Pro Tools.crash.log". You could post the log entry here and hope someone from Digi sees it and says "A-ha!".
If you don't have it on, here's how to do it.
I must say I'm glad Apple has this feature in OS X. In OS 9 you had to have MacsBug, which was arcane, involved user intervention, and if you didn't recognize it when it came up, you'd freak out.
Old 04-21-2003, 12:09 AM
Default Protools 6.01 Sudden Quit/Crash....
I'm having problems with PT6 suddenly Just quitting...Right to the finder. No error message, no restart message. I have tried repairing permissions, used disk warrior on my drive, Made sure everything is Mac HFS+, Re-installed my OS (10.2.3) to a clean drive. What gives?
Nothing I do seems to have any bearing on the problem...
what am I Missing?
-Todd A.
P.S.-Mirror door Dual 867. PT 6.01. Using firewire for session drives. Mix3 w/ 1 -888/24.
Old 04-21-2003, 12:31 AM
Ok, here's the latest-
Have now Re-initialized my HD. Re-installed the OS, redownloaded 10.2.3 from Apple. Re-installed that. Installed PT 6...And crashes. I dont get it. I'm pretty baffled now. this is starting to stink like a HW issue.
If anyone has any ideas, keep 'em coming.
-todd A.
Old 04-21-2003, 12:40 AM
houser houser is offline
Upgrade to 10.2.5?
That's what we are testing 6.01 with.
Not on long sessions but it definitely works and is stable.
regards
Janne A.
Old 04-21-2003, 12:47 AM
Jaguar cache cleaner?
http://versiontracker.com/dyn/moreinfo/macosx/16494
just fishing..
regards
Janne A.
Old 04-21-2003, 01:54 AM
S-pole S-pole is offline
We have the same experience. We have tried almost everything without any effect. Than we have changed one of the RAM DIMMs and it seems to be much better now. So it probably may be problem of incompatible RAMs. You can try it and let me know if it helps.
Pavel
Old 04-21-2003, 06:35 AM
undertone undertone is offline
Same problem here. Tried 6(.01) once, and all of a sudden the whole session and program wasn't there anymore.
Old 04-21-2003, 04:36 PM
Originally posted by stormtrooperpez:
I've got the same problem, and this is after a complete clean reinstall of the system software and PT 6.01. PT just quits right to the finder. Seems to only happen when I have the workspace browser open, but I haven't verified this yet. Doesn't seem linked to any specific actions or operations.
Dual 800 G4
1.25 GB RAM
HD 96 I/O
PT 6.01
OSX 10.2.4
<font size="2" face="Verdana, Arial">Yup. This is it...I thought it might be the workspace browser as well...but then it quit when it wasn't open.
I'm gonna try RAM now.
-Todd A.
Old 04-22-2003, 12:49 AM
stormtrooperpez stormtrooperpez is offline
Dual 800 G4
1.25 GB RAM
HD 96 I/O
PT 6.01
OSX 10.2.4
Sudden quit during DSP reallocation David Schober Pro Tools TDM Systems (Mac) 3 06-29-2008 09:31 AM
Recovering session information after sudden crash. homerg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-20-2006 09:02 AM
PT LE sudden crash on Mac OSX Eric Maia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-04-2006 10:35 PM
Sudden quit when adding MIDI track shadowbox Pro Tools TDM Systems (Mac) 7 10-31-2003 08:48 PM
LE 5.2.1 Sudden Freeze when Quit DooDooDoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-03-2003 05:48 AM
