After installing my Pro Tools LE 8.0 how it is told me by the install guide an Error appears.
When I start Pro Toolsm, Windows Vista gives the next ERROR while it was starting up: "Could not complete your request because Access violation occurred, unable to read location: 0x0D.535.A4F at address 0x74.155.74D in module: MSVCR80.dll" Does somebody maybe have a solution for this problem? |
Still Nobody has a solution for me
![]() It is also hard to get in contact with digidesign by Phone ![]() I will start a new threat with ERROR MSVCR80.dll maybe somebody knows more than |
Still nobody has solution cause still nobody has system report. No inf0 = no help.....
A new thread won't change that. |
![]() Quote:
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' ![]() NO, SHE'S WITH HOBO KEY ' ![]() ('we' must start using pronouns) |
![]() Quote:
![]() I though drop the de problem and hope to here something. Im not a computer freak that knows everything ![]() So my question: what kind off system report do you mean and where to find it, so I can drop it here. |
From the General Troubleshooting thread:
I googled MSVCR80.dll .
I came up with this link, which you should read and try to understand thoroughly: http://www.instant-registry-fixes.or...issing-errors/ In my own interpretation of your issue: MSVCR80.dll is a file in the C:\System32 folder that some applications need. From your explanation, apparantly, Pro Tools requires it. There are different versions of MSVCR80.dll . If a program needs it, then, it installs MSVCR80.dll when that program gets installed. In other word, reinstalling Pro Tools should reinstall the correct version of MSVCR80.dll . If the problem is a corrupted MSVCR80.dll file in the C:\System32 folder, you could just download a copy of that file and put it in the folder. But that could cause version conflict issues. It is best if you let the software reinstall it. Installing other programs could also take care of the reinstallation of MSVCR80.dll . .NET Framework 2.0 is a program that uses this file.
MBox 2 Pro connected to motherboard 4 pin firewire port Dell Inspiron 9300 laptop 2.0 gHz Pentium M 2 gB ram Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter Roland 700SX stage piano Studio Projects C3 mics Melodyne Plugin Dual Boot: PTLE 8.0.1 on Windows 7 Enterprise 32 bit PTLE 8.0.1 on XP Media Center SP3 |
System:
CPU: Name: Intel Core 2 Quad Q9450 Code Name: Yorkfiled Package: Socket 775 LGA Technology: 45nm Core Voltage: ± 1.096 v Specifications: Intel (R) Core (TM)2 Quad CPU Q9450 @ 2.66Ghz Mainboard: Manufacturer: ASUSTek Computer INC. Model: P5QL-E Rev 2.xx Chipset: Intel ID2e20 Southbridge: Intel ID3A16 LPCIO: Winbond Memory: Size: 4096MBytes Windows Vista Home Premium 64 bit Protools LE 8.0 Audiocard: M-Audiophile192 & M-box 2 Factory If there is anything missing let me know ![]() |
![]() Quote:
I will read yours en reply what I did and if it worked. Thanks |
Sorry my system is a 64 bit and this site doesn't work on it
error messages: -6101 & -9128 appears regularly :( | kolargol | macOS | 0 | 01-26-2013 07:37 PM |
Error when trying to start Pro Tools SE | kevinswaim | Pro Tools SE and Essential (Win) | 1 | 02-06-2012 07:41 PM |
Help Pro Tools will not start: error -36 while initializing | megalaser | Pro Tools M-Powered (Mac) | 1 | 04-07-2007 08:38 AM |
Please Help: Error #0 on Pro Tools Start-up | RichAucoin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-29-2005 01:23 PM |
Error Message appears when saving a new session | Anduril | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-14-2005 03:50 PM |
