New MTRX Studio installation
I am about to replace an aging Apogee Symphony with a MTRX Studio.
Its a HDX system so I assume that set up will straight forward. Couple questions: After setting up IO on DADMan do I have to then manually setup IO in Protools as well, matching the DADMan setup!? Not really clear from the research I did. Next up, I have been using an aging Hearback Headphone monitor setup. Its headunit witch get fed ADAT from the Symphony, spits out Cat6 cables to feed 4 monitor boxes in the Live room. Is there a simple solution that doesn't cost thousands of dollars, to send Dante from the MTRX Studio to a couple of headphone mixers in the live room, negating the ADAT to Ethernet box? Thanks in advance for any input! |
Re: New MTRX Studio installation
Greetings,
If you want to have explicit names for long term analog and digital IO which is normalled (via DADman > Con) to Pro Tools via DigiLink - then yes, you would need to label the IO paths for what they are in Pro Tools additionally. There are many different inexpensive Dante based headphone amp options. For small solutions - check out the Focusrite X2P or AM2. Up from there would be options like the KLANG and the HEAR Pro - which are a larger spend. best, Jeff |
As for the Dante monitor boxes from Focusrite, Klang and Hear Pro. For it to replace my old Hear system with 4 mixers would put me back at least $5000!! I think I will stick with ADAT and the old system! One last issue I had was, when I was testing out the unit I noticed that instrument input 1 on the front panel was not letting me plug in a guitar cord Input 2 was working just fine with the same cord. I will investigate further when the final install happens. Last edited by digiot; Today at 09:23 AM. |
The KLANG quelle is what I have and absolutely love it. Fabulous quality and exceptional low latency, and around $1800 for 4 headphone mixes. All of my mixes are created in DADman in the monitor profile - contributing sources from DigiLink, TB3, Coreaudio (omnibus), Dante, DADLink, analog, etc...
https://www.sweetwater.com/store/det...-headphone-amp best, Jeff |
Jeff - how are you controlling individual elements going to the Quelle? e.g. headphone mix 1 wants more of such-and-such.. for the PT source you can use sends but what are you doing for if they want less of another source? |
MTRX and MTRX STUDIO together? | kingtone | Pro Tools | MTRX & MTRX Studio | 4 | 06-05-2023 03:32 PM |
Where are the installation instructions for MTRX firmware update? | SomeOtherGuy | Pro Tools 2019 | 12 | 02-03-2023 10:43 AM |
Difference between MTRX and MTRX Studio? | snowplaysmusic | Pro Tools | MTRX & MTRX Studio | 4 | 11-26-2022 08:48 AM |
MTRX MTRX Studio Forum Section? | off the wall | Pro Tools | MTRX & MTRX Studio | 2 | 05-08-2022 03:20 PM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 11:00 AM |
