Further to PT-296357
I actually think there is a memory leak in
GetTrackList. I am using this command to poll protools. When i disable the call, my memory is stable. As soon as I enable the call, the memory starts to climb. |
Re: Further to PT-296357
Thanks!
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
I also made a couple of SDK changes that I'm testing now. Will advise if I have a positive update.
Thanks!
Is it ok if I send you my findings also? I've adjusted some sdk code and that has helped greatly. I just dont want to post code in here if that is not appropriate.
I believe the issue is to do with the rsp because if i make that static then the memory leak stops....but the command then becomes non functioning. Please keep me informed as this is the last hurdle I need to overcome to finish my app. Cheers |
Tope is in training so send the filets me directly so I can attach them to the case email is below. Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
Thanks, Marianna!
Hi damo76! I've sent an Email via the support case, please reply with your latest logs and other data so we can investigate further on this. Thank you!
