Old 12-11-2001, 04:29 PM
Mike F Mike F is offline
Default help!!! why no spdif input when selected in playback engine???
Ive noticed that switching the playback engine settings from 'ADAT' to 'SPDIF' uses less PCI resources. However , I can only get spdif in when ADAT is selected (& yes, Ive double checked my I/O settings)
Anyone know why selecting SPDIF doesn't allow spdif in??
PT5.1
OS9.1
G4 384 MB
thanks in advance
Old 12-11-2001, 07:10 PM
DigiTechSupt's Avatar
Default Re: help!!! why no spdif input when selected in playback engine???
-There are two different S/PDIF protocols...RCA S/PDIF and Optical S/PDIF (aka: TOSLINK).
-When you select "S/PDIF" as the Optical format (Setups>Playback Engine>Other Options window), it disables the RCA S/PDIF capabilities of the Digi001...this a hardware limitaion (the Optical and RCA S/PDIF ports share the same chip on the Digi001 card). You may, however, use RCA S/PDIF and ADAT Optical protocols at the same time.
Brent
Avid Audio Tech Support
Support FAQ
Old 12-11-2001, 08:42 PM
thank you Brent for your prompt reply, I'v e been stewing over this one for a while!
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
Playback engine & Input monitoring Stig Eliassen Pro Tools TDM Systems (Mac) 17 12-19-2010 01:24 PM
white noise coming from mbox when spdif selected djaikon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-23-2004 09:34 AM
playback engine - optical format spdif problem Mike F 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-21-2001 06:44 PM
