Old 12-08-2001, 07:33 PM
c.evans c.evans is offline
Default Anyone using Filter bank-Compressor bank
I am considering buying Filter bank and compressor bank for my set up, or upgrading to the Waves Gold bundle. I need some good plugins that are easy on the CPU.
Thanks, Chad [img]images/icons/tongue.gif[/img]
Home Studio Setup:
PT 9.0.5
Mac OSX 10.7.2
iMac 27"
3.4 GHZ 8 Core i7
8 gigs of ram
003 Factory
Chad Evans
Chief Engineer
Gaither Studios
Owner/Operator Big Mix Productions
Old 12-08-2001, 09:39 PM
Chompers Chompers is offline
Default Re: Anyone using Filter bank-Compressor bank
The "bank" stuff is great. However I seem to reach for the waves stuff first.
I dont have the waves at my home studio so, I use the "bank" stuff alot. I still prefer the waves. The Waves uses more CPU power than the others.
Old 12-08-2001, 11:17 PM
j creasey j creasey is offline
funny! i like the bank over the waves for eq and comps.they take more spl than others my 2 cents.
ps. cant beat the waves verbs thought!
james
Old 12-09-2001, 04:31 AM
Ben Jenssen's Avatar
McDSP RULES:
They can be a little "learning-curvey" but when you have used them a while, you wil not regret it:
Low(est) on CPU use
Sound terriffic
"The pro’s" say they’re quality
They can be configured to excactly what you need at the moment (also prserving cpu)
Very detailed control
Buy them!
Old 12-09-2001, 09:38 AM
tommydee tommydee is offline
is Filter Bank like a digital version of something like the Sherman Filter Bank??
or something else?
t.
Old 12-09-2001, 04:25 PM
dreeam dreeam is offline
I THINK EVERY BODY THAT HAS A 001 HAS THE GREEN FILTER AND COMPS ther coool in my book
easy on the cpu and easy to use [img]images/icons/smile.gif[/img]
Old 12-09-2001, 11:16 PM
Marso Marso is offline
Filter bank, yesss. Q10 is allright but sounds duller.(in my opinion of course)I achieve more easily my goal with them than waves. I think once you will work with FB you won't go back to waves.
I also like the features on the compressor bank, although, Renaissance comp. is also a really good comp. The waves bundle has a lot more than just comp. and eq. btw.
Old 12-09-2001, 11:52 PM
lwilliam lwilliam is offline
It seems I always reach for the Compressorbank before the Renaissance Comp. However, I do use the C1 whenever I want something a little more transparent than either.
The CompBank is much easier on the CPU than RenComp.
I would probably go for the filterbank, but I already own the gold bundle, so I use RenEQ or Q4 a lot.
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 12-10-2001, 05:30 AM
Red Wing Red Wing is offline
I've got FilterBank, CompressorBank and Analog Channel and I must say that I am completely happy with all of them. The most definitive way of making your own choices is to simply try the demo versions of the various contenders. I was all hyped on Channel Strip, it looked so cool, until I tried the McDsp stuff after and it was hands down and no turning back for me.
The McDsp stuff isn't as sexy looking and is indeed more complicated to fully maximize however sound should be the only real determing factor in what you use, shouldn't it? The presets will give you a very good starting point in terms of being able to get results form the McDsp products immediately. The crazy amount of control and possibilities shouldn't be considered a negative but rather an incentive to experiment and to develop better engineering chops. Just my opinion. Good Luck!
Old 12-13-2001, 09:11 PM
Thanks for the opinions on filter bank. It sounds like they are pretty impressive plug-ins, I'll most likely buy them.
Thanks, Chad [img]images/icons/smile.gif[/img]
Home Studio Setup:
PT 9.0.5
Mac OSX 10.7.2
iMac 27"
3.4 GHZ 8 Core i7
8 gigs of ram
003 Factory
Chad Evans
Chief Engineer
Gaither Studios
Bank D on SC48? Future Custom Bank perhaps? digidesigner VENUE Live Sound Systems 1 01-11-2010 07:20 AM
McDsp Compressor or Filter Bank RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 05-09-2009 12:37 AM
McDSP Filter Bank - Is it a CPU Hog? losttimestudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-15-2004 10:00 PM
Filter Bank Stereo Display? Extreme Mixing Tips & Tricks 1 01-13-2003 02:51 PM
Filter Bank P2 bug report Mark Haliday Tips & Tricks 1 03-12-2002 02:08 PM
