Old 08-14-2022, 06:42 AM
daeron80 daeron80 is offline
Default Feature Request: Add/Remove Controllers
The Add/Remove Controllers... feature in MIDI automation lanes should have checkboxes to automatically add new lanes to the current track or all tracks for each CC added to the list with the current operation.
E.g., the selected MIDI or Instrument track in shows only the default set of controllers (1,2,4,11,64).
  1. I open an automation lane, click on "velocity" and select "controllers-->Add/Remove Controllers..."
  2. I select one or more from the list and click "Add>>"
  3. I check the proposed box if needed (state is remembered from one operation to the next) to add new lanes to the current track
  4. One new lane is created for each newly added controller
The purpose of this is to avoid having to manually select the new lanes from the list after creating them. It's difficult to think of a time when I would want to add, say, CC18 to the list, but not want a new CC18 lane unless I were proactively adding many just in case they happened to be needed.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 08-15-2022, 01:03 AM
resonatee resonatee is offline
Default Re: Feature Request: Add/Remove Controllers
and even better would be for a midi region to 'remember' the CC lanes that were chosen in the midi editor, just like in cubase......
Old 08-15-2022, 11:35 AM
Ooo, I like that.
David J. Finnamore
Old 08-29-2022, 05:43 PM
To expand on that a little more --
There should be a keyboard shortcut to open/close the automation lanes.
There should be an option (modifier key while clicking the + button to make a new lane) that automatically creates a new lane for each CC number for which there is data in the MIDI Events list for that track.
Newly created individual lanes should by default be the next CC number for which there is data in the MIDI Events list for that track that doesn't already have a lane. Only if all data in the track is already accounted for should the new lane be for an unrepresented CC number.
I just finished modding the whole Spitfire BBCSO Pro Tools template, adding several new lanes to each track. Good grief was that a slog. Hours upon hours of needlessly repetitive mouse clicks. You'd think this was still the 20th century the way it works in PT.
David J. Finnamore
is the a hum remove (50hz) plug-in or feature floplight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-07-2007 05:49 PM
Feature Request garret Post - Surround - Video 0 10-19-2006 05:21 AM
Feature Request? Matt82au Pro Tools TDM Systems (Mac) 4 07-05-2006 05:12 AM
Feature request.. maybe this is already possible? Andy Hay Post - Surround - Video 10 06-28-2005 09:24 AM
Is this a feature that was remove?????? JROB6716 General Discussion 4 04-25-2001 09:11 PM
