Old 06-29-2022, 06:14 AM
jonpaulr123 jonpaulr123 is offline
Default Key command for opening plugins search window?
Hey guys and gals,
is there a key command to open the plugin search window? for example, if I'm I already have the track selected right now I have to click on the plugin slot then type in the plugin I want. I'd love to be able to hit a key and open that plugin search window. Does anyone know if this is possible? Thanks!
Old 06-29-2022, 08:16 AM
BScout BScout is offline
Default Re: Key command for opening plugins search window?
How would Pro Tools know which insert slot to put the plugin in with a key command? When you search, you first select the insert slot.
Old 06-29-2022, 08:34 AM
If it were command and then a number so that each number lined up with the appropriate slot, or if it just chose the first available slot. It may not be possible though.
Old 07-04-2022, 12:53 PM
soundgott soundgott is offline
It’s available from the key commands.
Old 07-04-2022, 02:18 PM
nednednerb's Avatar
nednednerb nednednerb is online now
example: https://youtu.be/lnRZWZtfrNg
Neat!
With link track and edit selection enabled and using keys semicolon with the letter p, along with custom shortcuts....
"Look, huh! No mouse!"
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Please add search function into Eucon command editor! Moviesound Avid S1, S3, Dock and Control App 5 10-03-2017 07:27 AM
Songs don't open if I've used the search window (tutorial opens instead) Desha Avid Scorch (iOS) Forum 1 06-06-2012 05:27 AM
Search feature in import audio window Studio Studio Pro Tools TDM Systems (Mac) 9 06-19-2007 03:51 AM
Crossfade shortcut launches search window daeron80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-28-2005 03:11 PM
No audio: Any "search for interface" command? Allan Speers Pro Tools TDM Systems (Mac) 2 10-22-2003 04:57 PM
