Old 07-09-2010, 10:21 PM
maxxdog maxxdog is offline
Default Constant CPU overload errors!!!
Sorry if this problem has been raised before - I've done a quick search but couldn't find an answer. I'm running PT 8.0.4 (just installed the update) and I'm getting constant error messages telling me my 'CPU usage is holding off, etc ... (-6104)', even though:
- the disk usage is running at about 15-20% with only a couple of % of Elastic audio (this level of usage has never been a problem)
- checked the compatibility of all plug-ins (no problems there, especially as they've been working fine until now)
- tried every possible combination of Hardware, Playback and Plug-in Buffer sizes (increased H/W Buffer size, used 1 and 2 Host Processors, upped the CPU limit to 90%, engaged and disengaged the 'ignore errors' option, etc, etc)
- have done everything digi suggests for optimizing my system
And yet, when the session craps out, I can't even play back a second of the song!!
What on earth is going on?
Old 07-09-2010, 10:24 PM
Default Re: Constant CPU overload errors!!!
FYI I'm using:
iMac, 10.5.8, 2.66 GHz IC2D, 4 GB memory.
The tracks are running from a WD ext HDD with very fast processor and samples are running off a second, similar ext HDD.
Old 07-09-2010, 10:27 PM
Actually, I should mention, I've just added a bunch of new Bomb Factory plugs - their high end compressors and the Pultec EQ emulations. They don't come up as incompatible on the digi list, but maybe ... ?
Buffer overload -6085 error constant mikesasa75 Pro Tools 10 11 02-22-2013 05:58 PM
constant CPU error overload!!! clintusmaximus macOS 1 12-06-2012 04:17 PM
Constant CPU Overload and DAE 35 Error AlissaAudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-20-2012 03:49 PM
constant CPU Overload and cannot play nor record franklebel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-15-2010 02:37 AM
Constant CPU Overload!!! Really annoying!! Help!! listenhard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-12-2009 03:31 AM
