Turning down volume in import audio window
Is there any way to turn down the volume in theimport audio window, or when you're auditioning cross fades?
http://www.streamload.com/NodeProps/...7&noCache=true |
Re: Turning down volume in import audio window
i believe there is a vertical fader near the playback controls in the import audio window that controls volume. fades are trickier to control- i don't know what hardware you are using but the fade is (i think) compiled with the MAC hardware and run through the DIGI hardware. the volume setting is probably controlled in the SOUND control panel. i don't think this setting has anything to do with protools-it is a mac thing. my fade previews are slightly louder than normal, but since i mix and edit somewhat quietly it is not a problem.
Import Audio Window | Desert Fish | macOS | 0 | 10-28-2012 07:55 AM |
Import Audio Window Bug in 905 | Zooce | macOS | 1 | 09-23-2011 01:08 AM |
Feature request - audio fader mods in Import Audio window | digidesigner | Pro Tools TDM Systems (Mac) | 0 | 04-22-2009 12:14 PM |
Import Audio search window results will not import | BA Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-25-2008 09:00 AM |
'Import audio' window is too big | rosebartu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-13-2005 10:36 AM |
