Hello,
I will give some bare details to see if anybody has any off the cuff ideas and can give more details about the rig if this seems to be a more detailed issue. I am running through an Asus Win 8.1 desktop with Pro Tools 11 and Mbox Pro. I am using a Yahama MO8 keyboard and have gotten the MIDI (virtual instrument) working where I can hear through headphones connected to the Mbox. However, I just bought a PreSonus Eris E5 monitor and hooked it up via 1/4" to the first line output on the Mbox PRO. I can still hear the output through the headphones but the monitor is not giving any sound. It is turned on and I went through the Mbox Pro driver setup and can't find anything wrong. The correct output (Main L/R Analog 1-2) is selected as the output. I also plugged the monitor directly to the keyboard and it is working, so it's not the cable or the monitor itself. I have a feeling I'm missing something simple from being a noob. Thanks for any feedback! |
A monitor or a pair of monitors?
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Just one monitor for now. I'm getting another soon haha.
None are labeled main or monitor on the MBOX Pro, there are just two headphone outputs and 6 line outputs on the back. |
Simple debugging first....
Do you know for sure that the monitor and cable works? Can you connect the monitor using the same cable to something else to test it? The cable should be an 1/4" TRS to 1/4" TRS (or XLR) balanced cable (not a instrument cable, although that would still get audio though if wired normally) But with an Mbox 3 Pro the most likely error is incorrect setup of the output in the Driver Control panel.... especially fat fingers pushing the front panel speaker button and cycling though output pairs. You *have* to read and understand the section it the MBox 3 Pro user Guide on Output Setup in the Driver Control Panel. You can also just test the monitor using the MBox Pro's low latency monitoring/hardware mixer and any old audio input you can get into the Mbox (analog line level from a CD player, etc), say set up a Stereo Mix for Output 1&2 in the Driver control panel .. that also shows you if the MBox 3 thinks it's putting a signal out on Output 1&2. Again all described in the User Guide. If you are still having problems and cannot get any monitor outs to work and the headphones still do then, post clear screenshots here of your driver control panel output setup dialog screen. |
And, remember to pan everything to the middle as anything on the side that doesn't have the speaker will not be heard at all
Fat fingers is right!
Last night I did read through the Mbox Pro User guide but I guess my brain was too fried. Read through it again this morning with a clear mind and figured out my problem after reading your post. Speaker button was sourcing to aux outputs instead of the line outputs. Thanks for the help! |
![]() Quote:
(mbox pro 2) no monitor sound coming out , while recording or anything period | JuiccMajor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-10-2012 01:34 AM |
MBox 2 Pro NOT Outputting Audio, please help! | tsandler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-11-2010 01:51 PM |
Fast Track Pro Outputting Mic input to Monitor, but Pro Tools 8 shows no mic signal | changa86 | Pro Tools M-Powered (Mac) | 3 | 12-18-2009 10:06 PM |
Mbox2 Pro stop outputting sound with Macbook Pro | Dual0568 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-16-2008 05:24 PM |
No monitor/headphone sound from Mbox 2 Pro | Welby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-17-2006 10:54 PM |
