Old 02-06-2014, 11:49 AM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
Default Crash report...
Heres the crashed thread part. anyone see anything suspect here so I can try and track down the issue.
I opened a previously working session and before the session even loaded got this crash.
Ive been doing EXTENsive trouble shooting and a part of that was re downloading all plug ins and re installing making sure the latest versions were in.
I had not oput back in the Slate RC Channel.
I opened said crashing session and it opened fine without the plug in. so I closed without saving.
added the plug in back into the DPM folder (since this plug in is not AAS yet)
trashed the DAE prefs
emptied trash (can't remember if I did it here or after restarting)
restarted
opened pro tools
hit open session
selected the same session that had previously opened with out RC channel
then crash.
Im thinking now this might be related to something I discovered in that after doing some prefs trashing (not sure if only when trashing DAE prefs but definitely when I select all in the PT PREFS utility) Pro Tools foirst opened with a RAM usage in the mid 2gigs or near there.
then I close pro tools and open again immediately and its back to normal ranges.
anyone else notice this?
I have reinstalled Pro Tools recently, and the drivers for Mbox 3Pro and all third party plug ins.
Repaired permissions, trashed prefs, (I in fact completely removed all prefs a couple days ago and have been resetting everything in an attempt to reach stability)
I'll continue trouble shooting myself just wondering of someone more experienced with reading crash logs sees something that might point me in a direction...
Process: Pro Tools [233]
Path: /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools
Identifier: com.digidesign.ProTools
Version: 10.3.8.378 (10.3.8f378)
Build Info: Unknown-10380378~378
Code Type: X86 (Native)
Parent Process: launchd [146]
User ID: 501
Date/Time: 2014-02-06 11:37:06.392 -0800
OS Version: Mac OS X 10.8.5 (12F45)
Report Version: 10
Interval Since Last Report: 44464 sec
Crashes Since Last Report: 1
Per-App Interval Since Last Report: 30699 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 3093794D-920D-7814-3F95-359E9E8304FD
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000004
VM Regions Near 0x4:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools
__TEXT 0000000000001000-0000000000143000 [ 1288K] r-x/rwx SM=COW /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation 0x98e38177 _CFDoExceptionOperation + 871
1 com.apple.Foundation 0x901a30b3 _NSAddExceptionHandlerForLock + 33
2 com.apple.AppKit 0x97df52ee -[NSViewHierarchyLock lockForReadingWithExceptionHandler:] + 485
3 com.apple.AppKit 0x97df5103 -[NSWindow _lockViewHierarchyForDrawingWithExceptionHandler:] + 99
4 com.apple.AppKit 0x98452ac9 -[NSView(NSInternal) _clearDirtyRectsForTree] + 55
5 com.apple.AppKit 0x97dfe461 -[NSView(NSInternal) _setHidden:setNeedsDisplay:] + 485
6 com.apple.AppKit 0x97dfe26c -[NSView _setHidden:] + 49
7 com.apple.AppKit 0x97dfe22a -[NSView setHidden:] + 41
8 com.digidesign.framework.DFW 0x0066bbcd DFW_PainterOpenGL:rawRect(Cmn_Rect<long> const&) + 7597
9 com.digidesign.framework.DFW 0x00558d61 TWindow::Show(bool, bool) + 401
10 com.digidesign.framework.DFW 0x00557d26 TWindow::Close() + 102
11 com.digidesign.framework.DFW 0x005568a5 TWindow::CloseAndFree() + 21
12 com.digidesign.framework.ProTools 0x0fbfad1c MFortressHWBPEntryPoint_exit_mfort6317_ + 18120562
13 com.digidesign.framework.DFW 0x0056f2e9 TView::Free() + 569
14 com.digidesign.framework.ProTools 0x1054170a LaunchProTools + 279994
15 com.digidesign.framework.ProTools 0x1051fe69 LaunchProTools + 142617
16 com.digidesign.framework.DFW 0x0056f188 TView::Free() + 216
17 com.digidesign.framework.DFW 0x0056f188 TView::Free() + 216
18 com.digidesign.framework.DFW 0x0056f188 TView::Free() + 216
19 com.digidesign.framework.DFW 0x00558a2b TWindow::Free() + 123
20 com.digidesign.framework.ProTools 0x1049c61d MFortressHWBPEntryPoint_exit_mfort6317_ + 27170931
21 com.digidesign.framework.DFW 0x00566dad TViewServer:oCreateViews(TDocument*, TView*, std::string const&, VPoint const&, bool, DFW_PropertyFilter const&) + 189
22 com.digidesign.framework.DFW 0x00566e5f TViewServer::NewTemplateWindow(std::string const&, TDocument*, DFW_PropertyFilter const&, bool) + 79
23 com.digidesign.framework.ProTools 0x104de3db MFortressHWBPEntryPoint_exit_mfort6317_ + 27440689
24 com.digidesign.framework.ProTools 0x102c5c03 MFortressHWBPEntryPoint_exit_mfort6317_ + 25243225
25 com.digidesign.framework.ProTools 0x0fa2001c MFortressHWBPEntryPoint_exit_mfort6317_ + 16175730
26 com.digidesign.framework.ProTools 0x0f9d8419 MFortressHWBPEntryPoint_exit_mfort6317_ + 15881839
27 com.digidesign.framework.DFW 0x005cab66 TODocCommand:oIt() + 54
28 com.digidesign.framework.DFW 0x0059878b TCommandHandler::PerformCommand(TCommand*) + 187
29 com.digidesign.framework.DFW 0x005990df TCommand::Process() + 31
30 com.digidesign.framework.DFW 0x0058eb8a TApplication::ProcessEvent(TEvent*) + 26
31 com.digidesign.framework.DFW 0x0058f4a0 TApplication::WakeUp() + 64
32 com.digidesign.framework.DFW 0x006f551b TApplication::CreateNewOSApplication(void*, void*, void*) + 667
33 com.apple.HIToolbox 0x938809bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
34 com.apple.HIToolbox 0x93708394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
35 com.apple.HIToolbox 0x93707780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
36 com.apple.HIToolbox 0x937075ca SendEventToEventTargetWithOptions + 94
37 com.apple.HIToolbox 0x9373b98e ToolboxEventDispatcherHandler(OpaqueEventHandlerCa llRef*, OpaqueEventRef*, void*) + 3108
38 com.apple.HIToolbox 0x9370883f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2538
39 com.apple.HIToolbox 0x93707780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
40 com.apple.HIToolbox 0x9371b655 SendEventToEventTarget + 88
41 com.apple.HIToolbox 0x938800b7 ToolboxEventDispatcher + 82
42 com.apple.HIToolbox 0x9387ff79 RunApplicationEventLoop + 240
43 com.digidesign.framework.DFW 0x006fea5b DFW_EventLoop::RunApplicationEventLoop() + 11
44 com.digidesign.framework.DFW 0x0058ec5d TApplication::Run() + 45
45 com.digidesign.framework.ProTools 0x104fc1b1 MFortressHWBPEntryPoint_exit_mfort6317_ + 27563015
46 com.digidesign.framework.ProTools 0x104fd6d4 LaunchProTools + 1412
47 com.digidesign.ProTools 0x0000f277 0x1000 + 57975
48 com.digidesign.ProTools 0x0001037a 0x1000 + 62330
49 com.digidesign.ProTools 0x0000effd 0x1000 + 57341
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 02-08-2014, 09:54 AM
Question Re: Crash report...
Apple code is being executed at the moment this crash occurs.
If you open this same session with plug-ins inactive (hold shift while opening), does the session open without crashing? If you remove the Slate plug-in from the plug-ins folder, can you open the session without crashing?
If the answer to both of these is yes, then the Slate plug-in is causing the crash.
Old 02-08-2014, 02:02 PM
Default Re: Crash report...
I think it is possible slate was the culprit, but I had not only installed the new AAX version but had deleted all preferences to trouble shoot and had to eventually restart the Slate drums and re authorize. myabe it was the non authorized plug in that was crashing the os.
either way I seem to be working again..
although my problems with the Air Instruments v2 are just again on hold as everytime I have some time to try and install and troubleshoot again, i can't seem to get them working reliably so I remove and get back to work..
Thanks.
Jay-J
System
Crash Report... Shifted Music Pro Tools 10 3 02-17-2014 11:11 AM
Crash Report Help... Shifted Music Pro Tools 10 6 02-03-2014 11:28 PM
Crash with PT 10.3.3 (crash report inside) powerjoe macOS 8 01-22-2013 10:33 AM
Best Crash Report ever!! suicune Pro Tools TDM Systems (Mac) 10 07-14-2009 12:58 PM
Major Crash with PT 7.3 cs5 crash report included RuffJazzRecords Pro Tools M-Powered (Win) 0 02-09-2008 12:43 PM
