dual monitor with db sound help!!
I have macbook running 7.4.2 on a mbox2 mini. I'm using Samson Resolve A65 monitors. I recently bought the hook up for a 2nd screen & when I connect it, it does work but I get a high db sound coming out of my Samson monitors. They are connected by 1/4" from mini to rca in the back of the speakers. I was told it might possibly be the cable and that I should switch to 1/4" to 1/4" balanced and that should eliminate the db sound. Before I go by the cables has any one experienced this or have any idea what it could be?
Re: dual monitor with db sound help!!
Oh, and the sound does go away when i disconnect the 2nd monitor (screen).
come on guys still having this problem.... No 1 has experienced this or knows some1 who has???
Try to find a high quality, shielded monitor cable.
Does the sound change if you move the cables around, or the monitor, or your speakers? It appears the the Mini doesn't have balanced outputs, so you're hosed there.. And do you mean a high freq. sound, or a high db (loud) sound?? Is it a hum or a squeal?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Using unbalanced or RCA connections (even worse) for speakers/monitors is definitely not recommended. Get yourself some balanced cables.
the sound doesn't change @ all when anything is moved. The sound is like when you get your ears tested and you hear those tones in the headphones but it is much worse. (Beeeeeeeeeeeee) ie... What is the purpose of shielded cables?
Slim, the Mini does not have balanced outputs.. Would using balanced cables still help? I'm guessing the monitors have balanced inputs..
The purpose of shielded cable is to isolate your good signal from EMI/RFI. Or in the case of the computer monitor cable, to keep the EMI/RFI from getting out..
It is also possible that some kind of loop is being formed with the USB cable, but that is why I was asking about the type of noise.. I'd say the squealy sound is interference from the monitor and/or the cable.. Is it a CRT or a flat screen monitor?
the shielded cables worked.. Thanks for your guys help.
What did you use to connect your second monitor?... Im running the same system and would like to add one or two
Dual monitor vs single monitor setup | Whasssaaahhh | Pro Tools 9 | 23 | 03-17-2014 01:24 PM |
Dual Monitor / hardware playback with NTSC monitor | TheBriceShow | Post - Surround - Video | 2 | 02-21-2005 05:58 PM |
Dual Monitor KVM | macr0w | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-06-2005 02:47 PM |
Dual 1.8 vs Dual 2.0 & LCD monitor recommendations | ikon1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-14-2004 09:33 PM |
Dual VGA Monitor G4 | ProductionEngelads | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 02-05-2002 09:53 AM |
