Re: MTRX Studio - Output fine, no input now
I sold my Omni for exactly the same reason. ADAT is probably your best bet without chewing up Dante channels for stuff like Atmos.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Thanks again, LDS!
So just to confirm: one doesn't need to combine the MTRX Studio with another digi interface in order to work in Pro Tools. If that's so, I can get rid of the entire HDN+Omni setup, and run things via an 8 ch. ad/da's adat i/o. Does that make sense? Last edited by Matt Stephanson; 08-25-2021 at 04:02 PM. Reason: Forgot to thank LDS :) |
Correct. If you are happy running FF PCIeR + MTRX ST -> that's fine. Just don't run DVS as your primary conduit to MTRX ST.
Jeff |
Got it, Jeff. Thanks, that makes sense. I need at least the MTRX + a RedNet card.
This sounds like a more stable system than just relying on DVS. I’m hopeful that will reduce the random dropouts I was getting. Cheers all! |
Depends what you are trying to achieve. The MTRX Studio with the HDN card will be pretty similar in function when using Pro Tools.
Yes - agreed. A few comparisons for engines to connect to a MTRX Studio:
HDX - Hybrid engine, DigiLink, 64 Channels of IO per card (up to 192 IO), Frame Edge Alignment (via SYNC X or SYNC HD), Dante available HDN - Native engine, DigiLink, 64 Channels of IO, Frame Edge Alignment (via SYNC X or SYNC HD), Dante available PCIeR - Native Engine, 64 Channels via CoreAudio, No Frame Edge, Dante allocated Jeff |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 11:00 AM |
MTRX Studio Output Analog Level Specs Discrepancy | Picture Start | Pro Tools | MTRX & MTRX Studio | 2 | 07-01-2021 09:03 AM |
ProTools MTRX studio - PT can't play, UA Apollo works fine | windmillaudio | Pro Tools | MTRX & MTRX Studio | 2 | 04-21-2021 02:37 AM |
Mtrx Studio DB25 Avid Cable for analog input | cerisaie | Pro Tools | MTRX & MTRX Studio | 11 | 11-16-2020 02:21 PM |
192 enclosed optical output seems dead! input working fine! | crizdee | Pro Tools TDM Systems (Mac) | 0 | 04-05-2008 11:16 AM |
