Hi all,
I'm having a little problem here. If I grab the sliders on the screen, it moves the faders on the digi003, but if I move the faders on the digi, it doesn't affect the protools??? Everything works fine if I mouse the screen...midi records..audio records, playback is fine....Any ideas? Was working fine before.... Beer |
Not many details here
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
I'll try it, thanks. I didn't post many details because it was working before so I know it's not my pc. It seemed like it just happened, I can't recall doing anything to cause it. I'll try the driver thing. If I can give you any more details, I'd gladly furnish them...what can I tell you about?
-= I |
Hey Albee,
I swapped through all the 1394 drivers and one worked! WTF?? The one I had been using was working fine and then, nothing. So I tried a couple of other ones and poof! Back in action... that was strange. Maybe it's the dreaded 1155 socket? Anyway, until recently my new build had been a monster and blazing. Lately it's been a little wonky. Here's a sandra... see anything weird? SiSoftware Sandra ID Host Name : Ivan-PC Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS P8P67 PRO REV 3.1 Serial Number : 1116245******** BIOS : AMI (OEM) 1904 08/15/2011 Total Memory : 32GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (4C 8T 3.71GHz, 3.7GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : ASUS Core (Sandy Bridge) DRAM Controller 100MHz, 2x 16GB DIMM DDR3 1.33GHz 128-bit Memory Module(s) Memory Module : Corsair CMZ32GX3M4X1600C10 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5) Memory Module : Corsair CMZ32GX3M4X1600C10 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5) Memory Module : Corsair CMZ32GX3M4X1600C10 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5) Memory Module : Corsair CMZ32GX3M4X1600C10 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5) Video System Monitor/Panel : Samsung SyncMaster (1680x1050, 22.0") Monitor/Panel : Samsung SyncMaster (1680x1050, 22.0") Video Adapter : NVIDIA Quadro FX 1800 (8CU 64SP SM4.0 1.38GHz, 768MB DDR3 1.6GHz 192-bit, PCIe 2.00 x16) Video Adapter : NVIDIA Quadro FX 1800 (8CU 64SP SM4.0 1.38GHz, 768MB DDR3 1.6GHz 192-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA Quadro FX 1800 (64SP 8C 1.38GHz, 768MB DDR3 1.6GHz 192-bit) Compute Shader Processor : NVIDIA Quadro FX 1800 (64SP 1.38GHz, 768MB DDR3 1.6GHz 192-bit) CUDA GP Processor : NVIDIA Quadro FX 1800 (64SP 8C 1.38GHz, 768MB DDR3 1.6GHz 192-bit) Storage Devices WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) : 466GB (D:) WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) : 466GB (F:) Mushkin MKNSSDCR240GB (240GB, SATA600, SSD) : 224GB (C:) TSSTcorp CDDVDW SH-222AL (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices DATA (D:) : 466GB (NTFS) @ WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) System Reserved : 100MB (NTFS) Back-Up (F:) : 466GB (NTFS) @ WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) Hard Disk (C:) : 223GB (NTFS) @ Mushkin MKNSSDCR240GB (240GB, SATA600, SSD) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SH-222AL (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS P67 LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASUS Cougar Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Serial Port(s) : 1 Disk Controller : ASUS ICH8R (ICH8) SATA RAID Controller Disk Controller : ASUS JMB362 AHCI Controller Disk Controller : ASUS 91xx SATA 6G Controller USB Controller 1 : ASUS Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : ASUS Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : ASUS ASMedia XHCI Controller USB Controller 4 : ASUS ASMedia XHCI Controller FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon Inkjet MP160 Printer (600x600, USB, Colour) Printer : Epson ESC/P-R (360x360, USB, Colour) Network Services Wireless Adapter : 802.11n USB Wireless LAN Card (802.11g (ERP), WEP n-bit, 54Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 6.7 Thanks again! Now if I can solve the new file access error, it'll be back to perfect! Atleast it's not coming up that often. Ivan |
Also for anyone that's interested, the driver that worked was the VIA 1394 OHCI Compliant Host Controller. I selected it according to Albee's awesome advice.
-= Ivan |
Well....you won't like what I have to say. I built a similar rig with an i5, same mobo, and 16GB of RAM and it was a total failure for Pro Tools(so good on ya for having success
I can't think of any changes really. It's working fine today, last night I tried the dverb test and got 200 with it maxxed out. Dunno if that's reasonable or not..seems in the ballpark. The hard drives are far from full. Half on the system drive, almost nothing on the data and back up drives.
I will definately grab that image software you're talking about. I need for sure! Then I have to find an 8.0 installer (scratched disk, working with digi on it) and I'm going to image and then try a clean install. Can't complain about how its working at the moment... getting a windows based file sharing error occassionally....we'll see! -= Ivan |
![]() Quote:
Back in the days of XP I ran the DAVEC Test on a P4 and it never ran right afterwards. ![]() I had to use Ghost to get back to a functional system. I no longer run any form of stress test on computers. ![]()
URBAN MUSIC- (Hip Hop and R&B) |
Protools really is magical when it's stable, but when it's feeling ill, good lord...
My most stable version was a 5.3 digi001 on XP running on a P3...LOL Bulletproof! Ugrade upgrade!! Pull your hair out! |
Protools 10 with Digi003 | Bjames | Pro Tools 10 | 4 | 02-04-2012 08:22 AM |
[HELP] Digi003 and Projectmix I/O on protools 9 | Ivaniponk | macOS | 0 | 06-24-2011 05:15 PM |
Protools controlling a SC48 | rivetheadsound | VENUE Live Sound Systems | 0 | 12-20-2009 03:33 PM |
Controlling Protools remotely | orourkeaudio | Pro Tools M-Powered (Win) | 0 | 01-07-2007 08:07 AM |
Controlling ProTools with Yamaha 01v | JonesH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-05-2005 12:21 AM |
