i have the wireless keyboard from apple and want to use my nudge commands and can't. can i reassign shortcuts somehow ?
thanks ian |
Could it be that your shortcut for changing nudge value zooms in and out of Pro Tools?
That's an OS X shortcut and can be switched off by pressing Option+Command+8 Hope it helps, Timothy |
nothing to do with zooming really. i want to nudge and on a wireless there isnt a numeric keypad like a normal keyboard. so i have to reassign the nudge keys if possible. anybody know how ?
![]() Quote:
Timothy |
A somewhat ham-fisted workaround would be to invoke the “Nudging by Next Nudge Value” commands. (From the PT 7.4 Reference Guide, pg. 473:)
Nudging by Next Nudge Value In addition to nudging by the current Nudge value, you can also nudge by the next, larger value in the Nudge pop-up menu. For example, if the Nudge value is set to 1 frame and you want to nudge by a larger valuer, you can nudge by the next, larger Nudge value of 10 frames. To nudge forward or back by the next, larger Nudge value: 1 Enable Commands Keyboard Focus (see “Keyboard Focus” on page 20). 2 Select the regions or notes you want to nudge. 3 Do one of the following: • Press Forward Slash (/) to nudge the selected material forward by the next Nudge value. • Press M to nudge the selection back by the next Nudge value. — IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
If you have Quickeys it's pretty easy to reassign. There are also other programs similar to Quickeys that aren't as expensive.
Keyboard focus - the little a...z widget in the top row near the left side of the edit window, another feature that I can't believe everyone doesn't use (I know to each his own, horses for courses, you can't stand that feature, whatever), assigns nudge to m , . / keys.
As Andre's post said if your in frames that's -5 -1 +1 +5 frame nudges. The manual is outdated it used to be 10, but it's been 5 for a while. |
So this keyboard doesn't have these keys?
< > With command focus on, these are nudge as well the + and - keys. |
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. | jessedtf | Pro Tools 10 | 6 | 10-24-2012 10:42 AM |
Change Grid and Nudge Value Shortcuts Not Working | jerosta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-06-2012 11:51 AM |
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? | EricHirsch | ICON & C|24 | 1 | 08-13-2009 09:07 AM |
Change the nudge value, not working | Sunzate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-14-2009 10:36 AM |
Keyboard Shortcuts-Apple Thin Keyboard | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-15-2008 04:17 PM |
